how to check timing?
Old Jul 22, 2006 | 02:02 PM
atmdc's Avatar
Default how to check timing?
ok i have an advance inductive timing light from sears that has a dial from 0-60 on the back. if my label under the hood says the timing needs to be at 18 degrees, do i just set the **** at 18 degrees and adjust the distributor untill it matches the strobe?
Old Jul 22, 2006 | 03:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: how to check timing? (atmdc)
Set it at zero and use the timing marks to the left of the
TDC mark on the crank pulley..
The one in the center of the three marks.
Make sure to jump the service connector before attemping to set..
Old Jul 23, 2006 | 10:10 AM
jlicrx's Avatar
Default Re: how to check timing? (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Set it at zero and use the timing marks to the left of the
Make sure to jump the service connector before attemping to set..</TD></TR></TABLE>
or, set the light to 18 and use the TDC mark (one by itself to the right of the three together)
Old Jul 23, 2006 | 07:21 PM
Hondasmo's Avatar
At work I usually just set the timing gun to the advanced reading the label under the hood list and use the white line on the crank pulley either way it doesnt matter if the gun is set at zero your just watching the red line on the distributer
Old Jul 27, 2006 | 07:16 AM
CoryB's Avatar
I've read about the service connector before but I can't find it on my car.
1990 CRX Si with stock D16A6 engine
Any pics or pointers on where it is?
Thanks.
Old Jul 27, 2006 | 10:58 AM
Dave_Darling's Avatar
Default Re: (CoryB)
Passenger footwell, in front of the door, over on the right side of the cabin.
--DD
Old Jul 27, 2006 | 11:22 AM
88DXCRX's Avatar
Default Re: (Dave_Darling)
Should be around the area indicated here:
Pic from manual:
The earlier models have the jumper
located under the hood:
Modified by 88DXCRX at 1:41 PM 7/28/2006
Old Jul 27, 2006 | 02:20 PM
Hah! Finally found the link again...
http://www.norcalcrx.org/ht.html#ignition
--DD
Old Jul 28, 2006 | 08:34 AM
CoryB's Avatar
Outstanding! Thanks to both of you for the link and info!
raverx3m
Apr 9, 2012 09:15 AM
1990si
Aug 7, 2006 12:34 PM
projectTeG
Mar 31, 2005 05:17 PM
IggDawg
Mar 13, 2004 03:27 PM
