quick question on clutch slave cylinder
Old Jul 22, 2006 | 12:23 PM
super_nguyen's Avatar
Default quick question on clutch slave cylinder
is it the same procedure as bleeding the brakes?? pump the clutch, hold and bleed the air out, then repeat? or is there anything else?
Old Jul 22, 2006 | 12:44 PM
crimsonv4mpire's Avatar
Default Re: quick question on clutch slave cylinder (super_nguyen)
same deal
close it before it's done spraying.
if you're gonna do it, might as well run a full bottle through it, nice and clean.
always helps to sucker a friend into pumpin the pedle.
Old Jul 22, 2006 | 04:25 PM
JSPECSIR's Avatar
Default Re: quick question on clutch slave cylinder (crimsonv4mpire)
it will bleed itself, as it is mounted lower than the resevior. just open the valve and take the top off the res. it will start pouring out the slave, make sure the res. doesnt run dry. when you dont see bubbles close the valve and pump the clutch pedal till it tightens up. (15-30 times)
95greenlude
Dec 20, 2004 09:24 AM
jwitey
Apr 4, 2004 11:54 AM
jdm_lude
Jul 14, 2003 01:25 PM
Civichatch972
Jan 1, 2003 08:10 AM
SupaTegRS
Nov 16, 2002 05:35 PM
