Timing Belt problems?
Not sure if this is my timing belt or not. but the noise is coming from the area where the timing belt is located. Ill let the car idle and every now and then it makes a click click noise. Symptoms is less power throughout the car.
Dont know.
Dont know.
I had the same problem, my idle would bog and the motor would shake
it ended up being my plug wires
try checking those and taking the car in for a timing adjustment so they can check and set the timing if needed
