High idle on my zc and gears are grinding
i just got a zc installed and its idling at like 2 as soon as i turn it on and it idles between 1.3 and 1.5 some say intake manifold gasket but is there a way i can make sure before i go through all the trouble of taking that damn thing off? plz help and 2nd gear grinds in high rpms if its the tranny fluid how do i change it on a manual tranny thanks
have u tried adjusting the idle?
there is a drain plug on the tranny...take it out and drain it...now to fill it you have two options...either pour it in from the vss hole or pump it in from the fill plug...it looks the same as the drainplug...u can stop pouring fluid in once it starts coming out of the fill plug
Ek4drcindy
10
May 18, 2011 04:13 PM
b18hondahb
16
Oct 13, 2006 05:40 PM
