SPARK PLUG WIRES
Old Apr 22, 2002 | 10:11 AM
NAZC's Avatar
Default SPARK PLUG WIRES
MY MSD WIRES KEEP POPPING OFF MY D16A6 DOES ANY ONE KNOW WHY THEY WOULD DO THAT? I CHECKED THE COMPRESSION FOR SOMETHING ELSE AND NOTICED THAT SMOKE CAME OUT EVEN THOUGH I HAD THE COMPRESSION TESTER SCREWED IN.
Old Apr 22, 2002 | 10:25 AM
Urban Business
Guest
Posts: n/a
Default Re: SPARK PLUG WIRES (NAZC)
turn off caps lock and re-type that
Old Apr 22, 2002 | 12:44 PM
TheShocker's Avatar
I'll do it.
Old Apr 22, 2002 | 12:52 PM
NAZC's Avatar
Default Re: SPARK PLUG WIRES (BoostRetard)
Sorry I'm at work and the program we use needs the caps to be on.
Old Apr 22, 2002 | 12:54 PM
jdmhondageek's Avatar
ah the ever popular "CAPS" picture. never fails.
To answer you question: MSD sucks. get NGK. I have never had a problem with NGK but have had several with MSD and other aftermarket.
Old Apr 22, 2002 | 01:08 PM
Urban Business
Guest
Posts: n/a
Default Re: SPARK PLUG WIRES (Ayanami)
plugs stick into valve cover via suction. push them down all the way w/ yer palm. they should dip in a bit. you can then twist but not pull straight out w/o effort
my apologies for being a dick
[Modified by TorteX, 4:08 PM 4/22/2002]
Old Apr 23, 2002 | 11:22 AM
ricodemus's Avatar
actually I had the same problem with my msd wires. I emailed the company and they offered to replace them, but I didnt feel like buying another set of wires to send those pos away. Anyway, when it came time to buy wires for my b16, I went NGK, those msd wires suck ***** (at least for the fit).
Old Apr 23, 2002 | 01:29 PM
Malgerus's Avatar
Default Re: SPARK PLUG WIRES (ricodemus)
I had good luck with Accel 300+ wires. just make sure you don't reuse your stock holders, because my set was missing the retainers, and it licked *****. make sure you get a complete set, and use the gel they give you, because I broke mine
GraphiteMW
Nov 7, 2006 03:55 PM
Comeback Kid
Aug 23, 2005 10:31 AM
scUba-stEve
Feb 8, 2005 05:37 PM
KekeK-18
Mar 29, 2004 05:40 PM
bey
Oct 31, 2003 06:13 PM
