rpm vs mph
Guest
Posts: n/a
im asking because my tack is currently unavailable right now
anyways, with a 4.785 gearing, at what mph does each gear reach redline at 8400rpm?
im asking because i want to use my speedo for my shift points since my tach is not available at the moment.
8400rpm 1st gear = ? mph?
8400rpm 2nd gear = ? mph?
8400rpm 3rd gear = ? mph?
8400rpm 4th gear = ? mph?
You can look it up on this Excel spreadsheet.
You'll need to change worksheets (using the tabs at the bottom) first, since the first worksheet shown is for ATS gears, not the stock gears. Click on the "ITR" tab for the USIM stock gearing. You can change the ratios on it and see the effect on the numbers. Or, use whatever tab corresponds to your gears if you have one of the other setups.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">You can look it up on this Excel spreadsheet.
is there a same spreadsheet but in Kmph?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8400rpm »</TD></TR><TR><TD CLASS="quote">
is there a same spreadsheet but in Kmph?</TD></TR></TABLE>
Sure, just change all the formulas, as follows:
1. Hit CTRL-H to do a replace.
2. Find what: 1050
Replace with: 652.44
Click "Replace All"
It should say that it made 355 replacements.
3. Repeat for every worksheet.
You should do the same thing to find the text MPH and replace all with KMPH so the column headings are correct (5 replacements per worksheet).
2. Find what: 1050
Click "Replace All"
psycheus
Aug 2, 2008 04:26 AM
Mikey3000
Sep 24, 2007 08:17 AM
TypeR0149
Oct 20, 2003 10:22 PM
