Automatic tranny fluid change.
Old Jul 21, 2006 | 11:11 PM
square_1's Avatar
Default Automatic tranny fluid change.
I know how to change the fluid, I know to loosen the filler bolt before the drain bolt just in case and such, but what I wonder is what tranny fluid would I use for an automatic? Everyone says Honda MTF but is there a Honda ATF also?
Also, if possible can I just fill the tranny from where I check the fluid from in from of the exhaust manifold? Or would that be bad considering I don't know how full it is?
Thanks.
Old Jul 22, 2006 | 07:14 AM
SIred91's Avatar
Rainman
Default Re: Automatic tranny fluid change. (square_1)
yes, use honda ATF, I dont hava a honda auto though, but yes you can also fill it from the check tube, just find your owners manual or call the dealership for info on how many quarts to put in.
Old Jul 22, 2006 | 09:30 AM
pimpwagon's Avatar
Default Re: Automatic tranny fluid change. (SIred91)
your car uses 2.5 qts of honda atf.
averyvm
18
Dec 13, 2010 04:03 AM
greenskittle
May 14, 2010 12:05 AM
x19trix72x
Oct 7, 2008 09:11 AM
lv6l
Acura TSX
10
Apr 6, 2007 10:22 AM
Brolli007
Dec 22, 2002 12:09 PM
