Oil in spark plugs?
So today I went to change my spark plugs (much needed!) and there was a semi-large amount of oil in every spark plug hole. The wire ends were dripping and when I pulled each plug out it dripped with quite a bit of oil.
Is there a seperate seal that goes around each of those holes from the valve cover?
How do I fix that?
Thanks!
How do I fix that?
Thanks!
I am not sure but i think the seal is actually the spark plug cables that have a boot that keeps the oil from getting next to the spark plugs.
That is what i think.
I looked around after I posted this. I did a search and some people say it doesn't help to change that stuff...
So when I change my valve cover gasket should I let my car sit for a while so all the oil drains down?
Will oil spill out when I take off the valve cover?
And for the heck of it I might just repaint my valve cover while I am at it!
Thanks!
Thanks!
