Please Help!!! Broken headlight selector!
Today, while changing my alternator, i got frustrated and "accidently" broke the headlight selector . The one that is on the left side of the steering column, and runs your turn signals also. Does anyone know how much they run for or how hard it is to install....Im totally clueless...i need help fast..Antone do a write-up?!...TIA!
go to a junk yard at the most it will cost 10 bux.
by the way u have to replace both the blinker switch and the windsheild wiper switch they are made together.
ok here is how to install:
1. remove the h emblem out of the center of ur stering wheel.
2. remove the big bolt behind the h emblem. then pull the stering wheel off.
3. remove the 2 bolts under the stering column that hold the plastic cover on. remove the bottom plastic cover then the top one will come off. (there will be a ring going around the 2 plastic cover u can figure out how to remove it.
4. u will see 2 screws down in the switch, like right behind where the stering wheel was. remove them, on both sides.
5. unplug the wires and pull it off.
6. then put ur new one on.
damn i need to do more how to wright ups.
i think i did a pretty good job at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex »</TD></TR><TR><TD CLASS="quote">
i think i did a pretty good job at it.</TD></TR></TABLE>
Not until you learn how to spell "write" and use the shift key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens »</TD></TR><TR><TD CLASS="quote">Not until you learn how to spell "write" and use the shift key.
Haha for sure
Here's a How To for writing How To's:
1.Always use proper grammar
2.Never use slang terms
3.Use lotsa pictures
4.Dont waste your time, it's unappreciated.
</TD></TR></TABLE>Haha for sure
Ok...thanks alot. I thought it was going to be a lot harder than that. So once i get that plastic steering wheel cover off...it's easy from there?.
Damn, best thing i ever did to my CRX was join Honda-Tech! Thanks guys
olivejdmmiami
Jan 18, 2014 05:31 PM
nene503
Apr 24, 2007 05:19 AM
FireMedic
May 23, 2003 04:26 PM
