Clock readjust itself when car is turned off???
I just bought a 1994 Del Sol DOHC Vtec. When I start the car my clock on the instrument panel is at 1:00. When I start driving the for instance 20 minutes... the clock will read 1:20... but as soon as I shut off the car and restart it the instrument cluster read 1:00 again??? Has this happened to anyone else? And if so how did you fix it?
Don't know if this helps in finding the root of the instrument gauge problem, but I am missing the VSS (Vehicle Speed Sensor) on the car.
blown fuse somewhere ....the clock is just resetting itsself whenever you turn the car off so it is not recieving the constant power it needs.....could be car wiring or internally in the clock....take it out and test to be sure that there is 12v constat going to the clock even when the car is off ....if there is not then youve found your problem .....if there is then you need a new clock
also found out it resets my radio clock and station settings too... could it be a constant fuse to accessories? i didnt know accessoriese let alone the radio would have a constant power supply. anyone know what it could be?
this happened to me in my 34 civic coupe it happned to be the backup fuse. it in the fuse box under the hood.
remeber ber to disconnect your battery before putting it in i dident it it just blew again. also im prety sure its a 7.5 a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit »</TD></TR><TR><TD CLASS="quote">this happened to me in my 34 civic coupe it happned to be the backup fuse. it in the fuse box under the hood.
remeber ber to disconnect your battery before putting it in i dident it it just blew again. also im prety sure its a 7.5 a</TD></TR></TABLE>
34 civic coupe huh!? ....i wonder if honda even had a car out then......lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">
34 civic coupe huh!? ....i wonder if honda even had a car out then......lol</TD></TR></TABLE>
lol i meant 94 but im sure you knew what i mean
rjizzle4shizzle
Jan 18, 2012 05:00 AM
StreetRiot_DRE
Feb 25, 2008 01:36 PM
