question about changing ignition switch and sensors
Old Jul 21, 2006 | 09:53 PM
bleedblue94's Avatar
Default question about changing ignition switch and sensors
history: car was originally an auto has now been converted to 5 speed, i have been forced to change all the lock cylinders on the car bc someone got ahold of one of my keys (long story) and just to be safe i got all new lock cylinders and ignition switch from a donor car to replace on my car. heres the problem, when i turn the key to the on position the guage cluster will light up but the fuel pump will not always prime. this made me think that the main relay may be going out however i have never had this problem before. then if you do it again it will work perfectly .....kinda like 50/50 chance.
the donor car for the locks and ignition cylinder was a 5 speed and on the ignition switch of the auto cylinder (the one originally in the car)there is room that 2 extra sensors go on. im wondering if anyone knows what these sensor are for? maybe on of these is affecting things.its just too great a coincidence that it is exactly when i change the lock cylinder that the main relay starts to go out.
btw car is a 98 hatch as i stated was auto now 5 speed...donor car for lock cylinders was also an ek
Old Jul 22, 2006 | 12:45 AM
drumminforev's Avatar
Default Re: question about changing ignition switch and sensors (bleedblue94)
it sounds like your ignition wires are making good connection. if everything lights up normal but no prime. does the check engine light come on for 2 seconds then off?
so i would isolate that to the main relay first. just remove it and look at it to see if the solders have any dry joints.
Awesome website for diagnosing ignition switch, main relay, ecu problems. Check it out for symptoms u are having.
http://techauto.te.funpic.org/ignitionswitch.php
Old Jul 22, 2006 | 06:08 AM
Default Re: question about changing ignition switch and sensors (drumminforev)
thanks like i said ill just be shocked if by coinicidence this is the first time i have main relay problems
does anyone know what the sensros that are on the ignition switch? im not tyalking about the switch at the opposite end of the key .... im talking about the 3 sensors on the ignition switch itself
Old Jul 22, 2006 | 09:23 AM
look at the website i sent you , it might tell you
Old Jul 22, 2006 | 05:01 PM
checked it out but didnt have the info i needed...thanks though
im pretty sure one is an interlocking switch but i dont know what the other is
Old Jul 23, 2006 | 07:45 AM
dgznhs
Old Jul 23, 2006 | 03:22 PM
shryhrs
Old Jul 23, 2006 | 06:50 PM
skljgjkhasdgh
Old Jul 24, 2006 | 02:32 PM
kffkd
Old Jul 25, 2006 | 08:06 AM
djmtuyjdtuy
fazalabbas
Jan 5, 2019 10:36 PM
Bishop1976
Oct 3, 2012 08:31 AM
cthack76
Apr 19, 2012 03:31 AM
boost fed ls
Jan 4, 2009 09:43 AM
