i don't know what body harness i have plz help
Old Jul 21, 2006 | 04:28 PM
crxsteve's Avatar
Default i don't know what body harness i have plz help
ok
i have a 91 crx hf
but the harness has been out of the car
so i don'tknow if they have sawped it or not
there is 3 plugs on the pass side one ciricle one big rectrinagle and then a small rectringle
on the driver side there is just one small rectringle with 6 wires
if you wunt a pic of this just email
at
Rags2wrenches@aol.com
i don't have the motor harness so i need to know what body harness i have
before i go and look for one
ok later
thanks
for the help
Old Jul 21, 2006 | 07:47 PM
y-49's Avatar
Default Re: i don't know what body harness i have plz help (crxsteve)
ok ppl i have benn trying to help this guy out. he dosent know if his car is a hf dx si or what. well we know it isnt a si cause it dosent have a sunroof. and he dosent have a engine harness so he needs to get a engine harness. but he dosent know what car to get the harness for. but here is a pic of his plugs where the engine harness plugs into. soo if u can help him it would be greatly appreciated(spelling)
thanks,
derrick
Old Jul 21, 2006 | 07:55 PM
Rywire's Avatar
Default Re: i don't know what body harness i have plz help (yellow rex)
ARE YOU FUC*ING KIDDIG ME! How many time do you have to post the same thing! Just bump it, why do youhave to start a new thread! OMG!
You obviously have a 88 harness there...
Old Jul 21, 2006 | 07:56 PM
G0crxG0's Avatar
That'd be identical to the plugs on my 88 Si (by looks)
The 3 plugs from the pass. side, and the one 6pin connector from the driverside.
I'm not positive, but I believe the plugs are the same throughout the years, it's the wiring itself that's different. I've seen some SI's with big 14 pin connectors on both sides, and some on one side, like the above pictured or mine.
OP: If you really want to solve this problem, go draw up diagrams on paper of your Plugs. Then list and number all the wires in order, and come post it.
With that much info it'll be a piece of cake to figure out your problem, and it'll take you a 1/2hr to do, well worth it
Old Jul 21, 2006 | 08:00 PM
Rywire's Avatar
Default Re: i don't know what body harness i have plz help (droppedcrxsi)
ok, he sent me better pix... thats a 88 si harness... Problem solved...
Old Jul 21, 2006 | 08:05 PM
Rywire's Avatar
Default Re: (G0crxG0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">
ok, to clear it up to the world.... the fast idle valve was added in 89 making the 6 pin a 8 pin...
88 (si/hf) has the 6 pin connectors on the drivers side.
88-89 dx have 14 pin connectors... there is a eacv power wire that is missing in 1 position that differs a 88-89 harness from a 90-91...
The 89-91 si/hf have a 8 pin at the drivers side plug...
the 89-91 si dosent have the ignitor wire running through here..
the 89-91 hf does have the ignitor wire runnng through here...
(Rywire)
Old Jul 21, 2006 | 08:47 PM
y-49's Avatar
ok while on the subject. my car is supposedly a si it is a 89 it has a round 8 pin plug on the driver side. it has a sunroof. it is y-49 color which i think only came on the sis not sure about that though. umm, but on the title it says 1.5 litre. dont flame me but just wonderin. i also heard that the si is the only crx with a sunroof but i had a hf before with a sunroof. but i was told that was rare. thanks for any help
Old Jul 21, 2006 | 09:05 PM
G0crxG0's Avatar
-My 88 CRX SI (also Y49 ) and every SI I've ever owned said Civic 1500 on the title.
-No HF ever came with a sunroof, although I have seen several HF's and DX's with Sunroofs, their aftermarket. Slightly rare, but not worth anything.
Old Jul 21, 2006 | 09:58 PM
y-49's Avatar
umm i had a hf with a sunroof and it was a factory sunroof. i was told that it wassent a hf but carfax said it was a hf and the rear said it was a hf. i dont know why it had asun roof but it was a factory one.
ask the member konshenz on here i sold it to him.
but thanks gocrxgo for the info on the 1.5 on the title
Old Jul 21, 2006 | 10:05 PM
thirteen20CRXSi's Avatar
Default Re: (yellow rex)
i got two dx's with after market sunroofs not very rare but damn leaky!! lol
Old Jul 21, 2006 | 10:10 PM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex &raquo;</TD></TR><TR><TD CLASS="quote">umm i had a hf with a sunroof and it was a factory sunroof. i was told that it wassent a hf but carfax said it was a hf and the rear said it was a hf. i dont know why it had asun roof but it was a factory one.
but thanks gocrxgo for the info on the 1.5 on the title</TD></TR></TABLE>
I can assure you no HF came from the factory with a sunroof. Not to say yours didnt have one, but it didnt roll of the assembly line with one.
The HF was a high fuel economy model, and this revolved around the car being lightweight. The whole sunroof assembly weights a ton, and is one of the heavier things removed from a HF to make it lightweight. So it'd be awfully self-contradictory of Honda to include a sunroof on some models of HF. Plus, the Sunroof was supposed to be a SI exclusive thing, so that'd be contradiction on 2 points.
I wont believe a HF came with a Sunroof from the factory until I see a Honda invoice from a dealership for an HF stating it had a sunroof, or I hear it from a CRX guru
Old Jul 21, 2006 | 10:31 PM
y-49's Avatar
i dunno but mine had a sunroof and it mounted the same way my si does and looked exactly the same. but hell i donno i think it was an hf i will call my buddy tommarow and see. it could be a roof swap. lol j/k
Old Jul 21, 2006 | 10:34 PM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex &raquo;</TD></TR><TR><TD CLASS="quote">it could be a roof swap. lol j/k</TD></TR></TABLE>
People do those.
Did your HF have AC?
Old Jul 21, 2006 | 11:07 PM
y-49's Avatar
naw it didnt have any acc. i put a sohc zc in it and all i had was alt. runnin on the engine. but y would someone do a roof swap just for a sunroof, i can understand for the glass roof like u.
Old Jul 22, 2006 | 04:59 AM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex &raquo;</TD></TR><TR><TD CLASS="quote">naw it didnt have any acc. i put a sohc zc in it and all i had was alt. runnin on the engine. but y would someone do a roof swap just for a sunroof, i can understand for the glass roof like u.</TD></TR></TABLE>
IDK some people do roof swaps from SI roof too HF roofs b/c they dont like their sunroofs....
Old Jul 22, 2006 | 06:59 AM
crxsteve's Avatar
yo
my crx hf 91 had ac ???
and it has a rear whiper blad on the back window
pll told me the wiper thing wasn't on a hf
but then my hf asloe has rear disc brakes
which where sawped out of something
it also has a body kit type thing on it
i have no clue
later
Old Jul 22, 2006 | 08:48 AM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">People do those.
Did your HF have AC? </TD></TR></TABLE>
you know A/C was a dealer option and not a standard. I have a 91 Si and it didnt come with A/C
Landman93
Feb 1, 2016 01:30 PM
alexpr
Jun 6, 2010 03:40 AM
crxbomb
Dec 30, 2007 12:46 PM
rewerbcrx
11
Apr 14, 2006 01:47 PM
