FS B16 H22 Del Sol Differential Mounts cams valve cover Lots of stuff! Got to go!
Cleaning out my garage! I figured if I don't need it, someone else might need it! I don't have any firm prices set please make me offers! Bump if you view! Will ship at buyer's expense!
1.b16/b18 valve cover, in great condition. Has small chip underneath where the spark plug cover would go. No cuts. Does not include spark plug cover or oil cap.
SOLD!!!!!!!!!!!
2.For an EF civic, the ignition part, comes with key. I'm not sure what else you would need. Perfect for if someone has broken into your car and f'd up your ignition
3.B16 Stock OEM differential. Out of a perfectly running hydro '00 B16 Tranny
4.H22 Cams and cam gears. Stock, not sure of mileage but look to be in good condition.
5.(2)H22 Driveside mount that bolts onto the block itself. - make offer
6.H22 Clutch. Will get pictures soon. No flywheel.
Sold!
7.Civic EG under hood fuse cover. No sticker
8.B16 driver side Mount for eg civics. SOLD
9.99-00 Civic SI shocks/struts. Also have rears. No leaks. Used for about 3000 miles.
10.alternator bracker for h22
11. CAN BE REUSED IF PLANNING ON SLEEVING - crank will need machining also
12. a/c mount thingy for h22
13. Zex Dry Kit
14. Mounts for b16 into EG includes Rear T, Timing belt side and Tranny mount - make offers
15. Lower Timing belt cover for H22 no cuts! In Great conition
16. Oil Pan from an H22
Modified by amy at 12:24 AM 8/30/2006
Modified by amy at 12:25 AM 8/30/2006
SOLD!!!!!!!!!!!
Sold!
13. Zex Dry Kit
Late night(EDIT: early morning now
) wish I was asleep, but standing watch to protect the birds bump!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">bumpy</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">bumpy</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">bumpy</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">oog boogy</TD></TR></TABLE>
