Diagnostic Port for OBD1 1.5 Civic (1995) / Car cranks but don't start
Old Jul 21, 2006 | 10:52 AM
slowslc's Avatar
Default Diagnostic Port for OBD1 1.5 Civic (1995) / Car cranks but don't start
Can someone tell me where it is ?
I looked in the passenger footwell on the side and could not find any port .. Is it somewhere else.
Problem
Car cranks but does not start. I checked
1. 12 ish volts at fuel pump (rear seat) AND IT PRIMES
2. There is fuel coming out of fuel filter ( in the engine bay) - could not check at rails
3. Ignition Relay seems to click
4. 5V at map sensor
5. No Spark ( I used a spark plug and grounded it) - no spark on leads
Any insights ? I just went to junkyard to pick a distributor and an ignition relay .. any more help from u would be nice..
Thanks
Old Jul 22, 2006 | 09:33 AM
slowslc's Avatar
Default Re: Diagnostic Port for OBD1 1.5 Civic (1995) / Car cranks but don't start (slowslc)
I checked for that obd1 diagnostic port again in the passenger foot well.. NOthing.. wtf ?
can someone help ?
Thanks
d
Old Jul 23, 2006 | 01:22 PM
slowslc's Avatar
Default Re: Diagnostic Port for OBD1 1.5 Civic (slowslc)
damn.. does anyone know ? woww.. thanks
d
Old Jul 23, 2006 | 01:24 PM
soMedic's Avatar
I had a similar problem on an old chevy once... it was a bad ground wire.... check the ones around the distributor and such.
oh yeah.... and be patient
-constantin
aquabob89's Avatar
* B A N N E D *
if your trying to check for codes. theres two wires around the ecu. connect them with a paper clip and your service engine light will blink. blah blah blah. then find out what the code means. ??? dont know if this is what you wanted.
95PreludeNAed
Jan 10, 2012 04:09 PM
slowslc
Sep 7, 2010 08:51 AM
dan617
10
Jan 31, 2009 02:10 PM
BIG DAVE
11
Oct 17, 2004 06:59 PM
mellowboy
Jan 28, 2003 02:08 PM
