3,500 redline?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank24 »</TD></TR><TR><TD CLASS="quote">Alright I swapped my 99 ek hatch out with a d15b. I am using a p28 ecu and my red line is 3,500? wtf?</TD></TR></TABLE>
your redline isnt 3,500...your engine cutoff is at 3,500...any CELs? Is the p28 chipped or stock, im pretty sure your redline for a d15b is somewhere around 7,000rpms last tim ei checked
is the ECU chipped? if it is it may be a srewed up chipping job, it also may be launch control. try driving it over 5mph and see what the fuel shut off is.
dank24, slowSOHCvtec is trying to help. is your CEL on?
P28 doesn't use a knock sensor.
if you have a distributor sensor code it will rev limit you low like that.
get your CEL in you cluster working first, no telling what bad things you've been missing out on. Check the codes and go from there.
if you still have your OBD2 ECU, unplug the conversion harness and plug it in. then you can use a parts store's scanner to tell you exactly what's missing.
you need a paperclip to check the codes. (and your CEL light of course)
check the sticky for how to check them.
also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">if you still have your OBD2 ECU, unplug the conversion harness and plug it in. then you can use a parts store's scanner to tell you exactly what's missing.</TD></TR></TABLE>
also...
update: somehow my cylinder position sensor got put in a different pinout to my ecu. So I am guessing that is why I had the 3,500 redline , which eventually killed my dizzy. I am hoping tomorrow will start right up with the new dizzy and have vtec!
helps to search
