what do i need for a b16 swap?
i have a 91 hatchback and planing to get a 1st gen b16 out of a ef crx or hatch...what will i need for the swap? any conversions cause its a jdm motor? will i have any problems with axles ect...thanks for your feed back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAYgasDC2 »</TD></TR><TR><TD CLASS="quote">ive searched it up...what i have found arent the answers to my question...</TD></TR></TABLE>
well then you really suck at searching... the info is out there lol. way to much to type and I'm not going to do a search for a member that should know better
https://honda-tech.com/zerothread/1696459
Honda Motors Online 6-18-02
--88-91 xsi B16a full change over kit XSI long block JDM XSI
--Rear mount bracket 50827-SK7-020 JDM XSI/ 90-93 Integra
--J1 tranny J1 JDM XSI
--Pr3 ecu 37820-pr3-003 JDM XSI
--Pr3 axles/ int. shaft DA JDM XSI/ 90-93 Integra
Total= $1250 + tax
--Hasport billet mounts 88-91 Civic/CRX EFB1
--Hasport linkage 88-91 Civic/CRX EFB1
Total= $400
Precision Auto Parts 6-26-02
--Alt. Belt (shorter than factory) Gatorback 4040300 90-91 Integra (original)
--Dist. rotor Boch 04277 90-91 Integra
--Dist. Cap Boch 03376 90-91 Integra
--Lower radiator hose ? 90-91 Integra
--4 spark plugs NGK 5724 BKR6E-N-11 94 Del Sol DOHC Vtec
Total= $58.07 + tax
Val Strough Honda 6-27-02
--Valve cover gasket 12341-PR3-000 94 Del Sol DOHC Vtec
--4 valve cover o-rings 12342-PG6-000 94 Del Sol DOHC Vtec
--8 valve cover grommets 90442-P30-000 94 Del Sol DOHC Vtec
--T-belt 14400-PR3-004 94 Del Sol DOHC Vtec
--W-pump 19200-P30-003 94 Del Sol DOHC Vtec
--Oil pan gasket 11251-P30-004 94 Del Sol DOHC Vtec
-- Fuel filter 16010-SH3-505 88-91 CRX Si
--Spark plug wires 32722-P30-000 94 Del Sol DOHC Vtec
--Oil filter 15400-P0H-305 94 Del Sol DOHC Vtec
--1 distributor bolt 90003-P01-000 94 Del Sol DOHC Vtec
--3qts. tranny fluid 08798-9016 Manual Tranny Fluid
--2 cam seals 91213-PR3-004
--Crank seal 91212-PR3-003
--Main oil seal 91214-PH1-004 94 Del Sol DOHC Vtec
--Shifter stabolizer washer (A) 54305-SA0-000 94 Del Sol DOHC Vtec
--Shifter stabolizer washer (B) 54304-SK7-000 94 Del Sol DOHC Vtec
--Radiator Cap 19045-PM3003 89 CRX Si
--Thermostat w/gasket 19301-P08-305 94 Del Sol DOHC Vtec
--Coolant CU08730 Honda Coolant
--Shifter stabolizer bolt 95701-08018-08 94 Del Sol DOHC Vtec
Total= $382.15 + tax
Butts Acura 7-5-02
--2 outer cv boot set 44018-ST7-C03 90-91 Integra
--2 inner cv boot set 44017-SK7-A00 90-91 Integra
--Upper radiator hose 19501-PR3-000 92-93 Integra GSR
--1 rear mount bolt (shorter) 90189-SF1-010 90-91 Integra
--2 rear mount bolts (longer) 90188-SF1-010 90-91 Integra
--Throttle cable 17910-SK7-A03 90-91 Integra
Total= $150.57 + tax
Ebay 7-9-02
--Vtec pre made wire harness custom made mate with si harness
Total= $51.00 + free shipping
Ebay 7-15-02
--Act (hd) pressure plate H025 90-91 Integra
--Koyo throughout bearing 062-1147-CB-54004 90-91 Integra
--Nachi pilot bearing 91006-634-008 90-91 Integra
Total= $250.00 + shipping
No Limit Enterprises 8-16-02
--Fidanza Aluminum flywheel H3MD7 Any B-series
Total= $309.00 + free shipping
No Limit Enterprises 9-11-02
--Act clutch disk organic street (ss) HSD807S 90-91 Integra
--Alignment tool AT87 90-91 Integra
Total= $134.30 + shipping
No Limit Enterprises 9-24-02
--DC sports 4-2-1 ceramic header HHC5504 94-00 del sol vtec/ civic si
Total= $287.00 + shipping
http://www.suspension.com 9-26-02
--Energy Suspension shifter stabolizer kit 16.1101G 94 Del Sol DOHC Vtec
Total= $9.00 + shipping
Total= 3,286.09 + some taxes
Modified by crxpwr1 at 5:13 PM 7/21/2006
Total= $1250 + tax
Total= $400
Total= $58.07 + tax
Butts Acura 7-5-02
Ebay 7-9-02
Ebay 7-15-02
stripes777
Mar 4, 2004 01:26 AM
KevronsEG
Feb 3, 2002 06:09 PM
