my eg is blowing white smoke when i start up
Old Jul 21, 2006 | 09:31 AM
cheeksnme's Avatar
Default my eg is blowing white smoke when i start up
i got a eg with gsr motor and turbo. When i start the car it will blow a cloud of white smoke. Whats the best way to find out what the problem is?
Old Jul 21, 2006 | 09:47 AM
PLAN:B's Avatar
Default Re: my eg is blowing white smoke when i start up (cheeksnme)
Compression/ Leak Down tests
Could just be condensation. Is there more smoke than what looks normal? Is this the first time you have noticed it?
Old Jul 21, 2006 | 09:49 AM
byronl's Avatar
check your coolant for oil mixture or your oil for coolant mixture.
Old Jul 21, 2006 | 11:31 AM
cheeksnme's Avatar
its more smoke than normal. And at stop signs when going into first i can see a little smoke.. So compression/leak down test? how much does that cost? i will check the coolant today. what if there is oil? then what is it?
Old Jul 21, 2006 | 11:48 AM
Lewy. Dee Ayy's Avatar
Default Re: (cheeksnme)
compression test =
40 doller tester..and u do it urself.
Old Jul 21, 2006 | 11:51 AM
byronl's Avatar
if u c oil in ur coolant than most likely its your headgasket thats gone bad.
whatala
Sep 26, 2006 12:10 PM
Hulk_EJ8
Jun 5, 2006 12:43 PM
VvPeachyvV
14
Dec 9, 2004 06:38 AM
Driven
11
Oct 29, 2004 11:41 AM
t616
Jun 21, 2003 02:35 PM
