H23 Vtec - Mahle Gold series pistons... CR questions??
IM thinking about trying out the MAHLE GOLD SERIES... in a all motor build though.
I see you can get a 11.5 CR piston.
Question... if you use a H23 block, rods, and crank, wth a H22 head - I know this increases the CR .. but how much? It doesnt have to be street driveable..
Ideas? has anyone done this yet??
I would mate it up to a head with crower stage 3s...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 »</TD></TR><TR><TD CLASS="quote">h23 block. i used manley turbo tough rods and wiesco pistons.</TD></TR></TABLE>
I was asking the CR for which engine, if the pistons are 11.5 on an H23 and you put on an h22 head, you will get a much higher CR, but if they are H22 pistons then it be as high because of the different volumes
BUMP... i think you guys are confused by my question...
Im not looking for 11.5CR... those are the CR of the pistons listed on Mahle website. Thier H22 pistons.
I would like to build a H23VTEC engine... using the above mentioned pistons.
I would like to get into the 14:1+ range.. is it gonna be possible with these 11.5CR pistons with H23 rods, and H23 crank???
I don't know the success people have had with the Mahle gold in the FRM but if you're looking for a serious motor build, which it appears you are if you are wanting 14:1 compression
You might consider just sleeving the block, also you also might want to look into such possibilities of headwork to achieve a higher CR rather than pistons with a huge dome. By having a large dome you also have less turbulence, worse fuel atomization, and greater separation of the combustion chamber... just something to think about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykid »</TD></TR><TR><TD CLASS="quote">I think I found my own answer...
gonan be around 13+ CR ratio.. which should owrk just fine.
If anyone can cnfirm this, and has some experiance.. let me know.</TD></TR></TABLE>
I came up with 12.8:1 compression
in theo ther thread someone said the MAHLEs actually come out to be about a 12:1CR piston casue of their volume or something. Like I said im new... I would like to make about 275WHP... and no im not looking for a daily driver, its gonna be a race car.
What would I expect with the Type S... I see thier a bit cheaper then the Mahles, and I dont wanna sleeve a blcok this year... if I do, im not gonna go high cr.. im gonna go low and try to go fast with big boost.
I would like to go high 11s in a street car build. EG HB. Slicks and race gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykid »</TD></TR><TR><TD CLASS="quote">in theo ther thread someone said the MAHLEs actually come out to be about a 12:1CR piston casue of their volume or something. </TD></TR></TABLE>
if you can find out the dome CC of the pistons I can be more exact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power »</TD></TR><TR><TD CLASS="quote">
if you can find out the dome CC of the pistons I can be more exact.</TD></TR></TABLE>
I found somewhere listed them at 10 cc which would brind it to 13.6:1 in a H23 VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power »</TD></TR><TR><TD CLASS="quote">I found somewhere listed them at 10 cc which would brind it to 13.6:1 in a H23 VTEC</TD></TR></TABLE>
Yeah thats what i was thinking aswell... that would be alright, i dont think i can mill the head at all from what im reading, but 13.6:1 should work fine for what i need.
Thanks guys.. if and when we get the project underway, there will be plenty of pics and ill try to share some info.
REDLUDE4WS
Oct 29, 2012 04:44 PM
koreachangsu
Sep 5, 2008 11:14 PM
