LHT intercooler and ITR, throttle cable too long!!
I am just finishing the install of the LHT intercooler and the only thing holding me back from starting the car is the throttle cable. Anyone know how I am supposed to installl the throttle cable.
LHT put a small bracket at the end of the end tank but it is too close for it to work. the whip of the throttle cable is too long so there is a lot of slack.
LHT is on vacation until the 24th, I have a dyno time scheduled on the 25th, I would like to know what I need to do that before so I have time to find parts if needed.
Hondata Tuning did a JRSC install and they talked about using a GSR throttle body because the bracket is attached to the TB but that woudl not still work unless I buy the throttle cable as well,
Could I use the GSR cable on the ITR?
Any help is appreciated.
Thanks
Thanks
The roller bracket is the one I took off the original JRSC intake. IT IS NOT BOLTED TO THE LHT NOR THERE IS A PLACE TO DO THAT, I just put it there to show where JRSC had their bracket at.
As you can see the only bracket LHT gave me was that on the side of the tank. It is too close to use with the ITR cable. And even if I welded the JRSC bracket/roller, the throttle cable would rub against the edge of the water tank, adn with time that is asking for trouble not to mention it is not safe at all.
That was my car in Honda Tuning. The GSR throttle Body is the best solution. since it uses the gsr cable and the correct throttle stay. The angle on the bracket on your manifold is to great and it will wear out a cable fast.
You can get the GSR TB bored out to the same specs as the ported LHT TB tube by RC Engineering (www.rceng.com).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">That was my car in Honda Tuning. The GSR throttle Body is the best solution. since it uses the gsr cable and the correct throttle stay. The angle on the bracket on your manifold is to great and it will wear out a cable fast.
You can get the GSR TB bored out to the same specs as the ported LHT TB tube by RC Engineering (www.rceng.com).</TD></TR></TABLE>
I have used the throttle cable bracket and the pulley off of a GSR and put them on the ITR tb and it works that way also
Message me if u like. I can get hold of him if you need me too. He's out of the country visiting England (his hometown). He's a close personel friend of mine.
I can help you if you like,
~Bert
Eghatchgsr8
Oct 11, 2014 03:09 PM
Renegade
Jul 24, 2006 07:09 AM
