crx intake maifold upgrade
Old Jul 21, 2006 | 04:06 AM
civic minime's Avatar
Default crx intake maifold upgrade
wich intake manifold would be a upgrade for crx 1.6l 88-91 and thottle body,fuelrails and injectors.going multiport but insted of using stock manifold from crx 88-91 i might as well get knew parts. ani input please.
Old Jul 21, 2006 | 04:12 AM
ludesrv's Avatar
Get a Y8 intake manifold, it's what I'm doing now thanks to Bart. He convinced me too.
Old Jul 21, 2006 | 04:20 AM
661rex89si's Avatar
y8 go for it im about to do that aswell it will be worth it some people even choose those over aftermarket intake mani's since these flow about the same for way cheap.
Old Jul 21, 2006 | 05:36 AM
Default Re: (661rex89si)
what about the thottle body fuel rail and injectors
Old Jul 21, 2006 | 05:42 AM
661rex89si's Avatar
what do you mean what about them they should come with intake mani. and you will be ok once you do the mpfi swap
Old Jul 21, 2006 | 05:43 AM
Loserkidwac's Avatar
Default Re: (civicdx(dpfi))
You won't need a new fuel rail, stock will work just fine and injecotrs you shouldn't need unless this is a built or boosted motor
Old Jul 21, 2006 | 05:51 AM
Default Re: (ludesrv)
d16y8 manifold will it work on 90 civic dx auto if it does what size of injectors needed
Old Jul 21, 2006 | 05:57 AM
Default Re: (Loserkidwac)
stock fuel rail and injectors and thottle body too
Old Jul 21, 2006 | 06:09 AM
What are your power goals, I think if you go with a larger TB you will loose some bottom end but probabaly improve the middle and top
Old Jul 21, 2006 | 08:36 AM
iam going to mpfi. the intake manifold needed for that is a crx 1.6l but instead of getting it from junkyard. i want to get brand knew 0ne but the up grade version of that. i was told it is the d16y8.what year car does manifold cames off.
Old Jul 21, 2006 | 04:45 PM
d16vtecx's Avatar
it comes on 96-00 civic ex's
but the one you want is from 96-98
99-00 has a different flange
Old Jul 21, 2006 | 05:01 PM
1990si's Avatar
will a y8 manifold bolt right up with sensors? I was told its lacking an intake temperature sensor
Old Jul 26, 2006 | 06:29 PM
Default Re: (1990si)
from the information i have and pictures,the sensors are the same in your case,but in my situation i am going to have to splice wires.i just recently found out that it does matter if car is an auto or manual,i have an auto i heared that i woul have to drill a hole on the intake in order to instal some kind of valve?
tamadrumr88
Jun 19, 2014 01:16 PM
racerx510
Nov 12, 2012 11:07 AM
Vince_badaz
Jun 8, 2003 10:46 AM
Toptul_Honda
Jan 11, 2003 09:11 AM
