swap..just quick question
Old Jul 21, 2006 | 12:50 AM
VRD^suzie's Avatar
Default swap..just quick question
okay..very quick question..i search but still need more feed back..
thing is im doing a b18b swap into crx..converting to obd1..thing i need to know is axles..i read that you can use the 94+ axles as long as you use the 94+ intermeditate shaft..correct??this is for the driver side axle...i know any bseries passenger axle will work..or do i need to use the DA inter. shaft plus the DA axle..more input please..thanks..
Old Jul 21, 2006 | 01:08 AM
crxnj's Avatar
Default Re: swap..just quick question (payo_vang)
Yeah you can use the 94+ integra halfshaft and axle(s)..It works fine..
The thing is though, if you're using a cable transmission you have to use a 94+ axle seal or it will leak alittle
Old Jul 21, 2006 | 01:37 AM
VRD^suzie's Avatar
Default Re: swap..just quick question (Mr.speaker)
cool thanks..more input please..
Old Jul 23, 2006 | 07:42 PM
Crackback's Avatar
The proper axles can be consturcted by using 86-89 integra axles with 90-93 integra inner joints. If the 90-93 integra intermediate shaft is used(some people opt to use the 90-93 axles) I suggest changing the outer joints to that of the 86-89 integra.
Old Jul 23, 2006 | 07:49 PM
charlee's Avatar
Default Re: swap..just quick question (Crackback)
what for if he can just use dc axles?
Old Jul 23, 2006 | 09:44 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by payo_vang &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks..more input please..</TD></TR></TABLE>
Mr.speaker is correct.
I'm running a 94+ integra intermediate shaft and driver's side axle in my CRX. No problems.
Old Jul 24, 2006 | 01:40 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crackback &raquo;</TD></TR><TR><TD CLASS="quote">The proper axles can be consturcted by using 86-89 integra axles with 90-93 integra inner joints. If the 90-93 integra intermediate shaft is used(some people opt to use the 90-93 axles) I suggest changing the outer joints to that of the 86-89 integra.</TD></TR></TABLE>
No need for that..
Old Jul 25, 2006 | 09:23 PM
VRD^suzie's Avatar
cool thanks guys!!
pigeonnn
Jul 28, 2011 12:10 PM
efmike84
Feb 21, 2008 04:08 AM
lilpastrana
Sep 6, 2007 07:30 AM
poppypizza
Jan 21, 2007 06:42 PM
foursquarepunk04
Feb 3, 2004 08:42 PM
