transmission pops out of gear???
I just bought a del sol with the stock b16 in it. Everything is ok except for a missing Vss sensor. Also everytime I pop it into fifth gear and drive for about 10-20 seconds it pops out of gear. does anybody know why? could it be that the VSS is missing? please help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 707EF8 »</TD></TR><TR><TD CLASS="quote">I just bought a del sol with the stock b16 in it. Everything is ok except for a missing Vss sensor. Also everytime I pop it into fifth gear and drive for about 10-20 seconds it pops out of gear. does anybody know why? could it be that the VSS is missing? please help.</TD></TR></TABLE>
Syncro is fugged.
Syncro is fugged.
Why would a synchro have anything to do with it? That's just for lining everything up and matching the two different speeds of the gears when changing gears.
Sounds to me like it's a bent/almost broken shift fork.
A friend's tranny had this issue and it had nothing to do with the shift forks, as they were still in great condition. It's probably the synchro/sleeves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge »</TD></TR><TR><TD CLASS="quote">Syncro is fugged.</TD></TR></TABLE>
While I am sure that you're an advocate of that "JDM Knowledge" You are still wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">Why would a synchro have anything to do with it? That's just for lining everything up and matching the two different speeds of the gears when changing gears.
Sounds to me like it's a bent/almost broken shift fork. </TD></TR></TABLE>
Yep, either that or fucked up dog teeth
Fucked up dog teeth:
I don't feel liek explaining right now
*yawns
*yawns
Whoops... I had the wrong terminology. *Blushes*
Bense is correct. 'Dogteeth.' Due to the material they have the ability to round off very easily. I figured the synchro and the dogteeth would be considered of the same. Broken synchro springs do weird **** too.
this is a simple fix. check your tranny fluid i am willing to bet it is low.i found out the hard way when a b series tranny is low on fluid it will pop out of fifth.
ok i will check the fluid... i just bought the car and found out that the vss was missing. i replaced the vss right away but didnt add trans fluid. probably when i drove it home some of the trans fluid left the tranny thus causing fifth to pop out. im going to check now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">
dog teeth was what i was thinking of, but i didnt know the proper terminolgy thanks. Next time come up with something original if your gonna insult me.
holy crap! i wish i had thought to check the oil before i destroyed my first b16 tranny. but then again it might not have been oil. cause it had no serial#
