converting to power windows
Old Jul 20, 2006 | 10:15 PM
jclamor87's Avatar
Default converting to power windows
How would i convert my 1993 honda civic DX into power windows
i have all four doors from an EX but is there any wiring involve that i have to take the dash board off or is it plug and play????????????
Old Jul 20, 2006 | 10:26 PM
melsers's Avatar
Default Re: converting to power windows (civicB18c1cjsc)
If you have all the wiring harnesses its plug and play
oh and you need fuses and the power window relay to plug in the fuse box
Old Jul 20, 2006 | 11:34 PM
.Kevin.'s Avatar
Default Re: converting to power windows (melsers)
find a totaled ex coupe and pull the entire set up from it.
Old Jul 21, 2006 | 08:03 AM
jclamor87's Avatar
Default Re: converting to power windows (Ep_Kevin)
i already have the doors but im wondering if i have to do any wiring behind the dash board
Old Jul 21, 2006 | 10:18 AM
travelor101's Avatar
YUP. Depending on how you want to go about it. What I did is I went to a junk yard, found an EX, put my fut on the dash and the other roughly where the center console was, ripped the **** out of the dash to get out what I could not with tools (in a timely manner), and seperated the wiring coming directly from the door jams. You'll find that there are two wires that lead to two "other plugs," and the rest is straight forward as to where it plugs up between the door jams and the fuze box. All you have to do is find the two plugs that resemble the two extra you have on the harness you pulled and splice them in. I layed the power door harness right over the top of the original door wire harness that existed. It may sound choatic, but it really is straight forward once you get under the dash.
Another way to do it without pulling the dash is to just cut them at the door harness, get your own colored wires and mate them up accordingly. For that, you will have to ask someone else though. I have only done what works for me.
Wish you luck...
Old Jul 21, 2006 | 10:23 AM
stwano's Avatar
Default Re: converting to power windows (travelor101)
dont mean to hijack... but where are the grounds for the power windows?
i used a mulitmeter and it seams i have no ground from inside the cabin???
Old Jul 21, 2006 | 10:29 AM
Default Re: converting to power windows (caliscrilla)
Pick a spot, drill a hole, scrap the surface paint to expose the metal, wrap the ground wire around the screw, screw it in, and your done.
I will add thoguh, that after I did this, the car shocked the hell out of me for a while, so uhhh... this is all at your own risk.
Old Jul 21, 2006 | 11:08 AM
stwano's Avatar
I think i would rather use stock ground locations, anyone kno where their at>?
Old Jul 21, 2006 | 11:23 AM
What I do know is that the stock locations (good idea by the way), if I remember correctly, flow right back to the wireharness plugin in which it gets fed through the rest of the wire harness. What I noticed is that with the power door harness, there is one or two more negative lines that are larger due to the use of power options. That is why I chose to go the route I did... I think. Using the stock locations is definately a good idea, so if any one true guru knows how to work this out, "bless" us with your knowledge.
Old Jul 21, 2006 | 12:00 PM
jclamor87's Avatar
so you had to take the dashboard out to do it the way you did it and i have to get a wire harness
Old Jul 21, 2006 | 01:25 PM
Pretty much. To keep it short this time, I got the door harnesses, and fished out the harness between the doors / under the dash, and plugged it in right over the top of the existing under-dash harness. The two extra wires mate to the plugs that are pre-existing and meet up at the fuze box under the dash. It is a lot more simple than it sounds.
I recomend pulling the entire harness setup and you will be in the mix.
CTR_B
Jan 28, 2010 03:08 PM
jooky5
13
Aug 31, 2009 08:40 PM
EARLdaSQUIRREL
Jan 26, 2005 09:38 PM
moleodonuts
Jun 28, 2004 08:52 AM
rob d
Nov 19, 2002 04:30 AM
