rear disc swap????
Old Jul 20, 2006 | 08:41 PM
streetracerjoey210's Avatar
Default rear disc swap????
if i were to do a rear disc swap on my 92'vx.... would i have to get bigger rims?
the rear disc brake setup is from a 99 si, are the rotors slight larger then my rear drums...
Old Jul 20, 2006 | 08:44 PM
G2 Speed's Avatar
Default Re: rear disc swap???? (streetracerjoey210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerjoey210 &raquo;</TD></TR><TR><TD CLASS="quote">if i were to do a rear disc swap on my 92'vx.... would i have to get bigger rims?
the rear disc brake setup is from a 99 si, are the rotors slight larger then my rear drums...</TD></TR></TABLE>
not sure, but they are bigger then the drums, but at the same time the rims on a 99 si are 15", so I'm pretty sure 14" would clear it but search to double check
Old Jul 20, 2006 | 09:00 PM
Default Re: rear disc swap???? (G2 Speed)
my vx's rims are 13'in..... you might be talking about the 14'in know as HX's
Old Jul 20, 2006 | 09:01 PM
BlueIntegraBoy's Avatar
The rear discs are not larger than the stock 9.5" discs. You can run 13" rims if you like. My friend is running 13" steelies on his rear disc swapped EF.
Old Jul 20, 2006 | 09:02 PM
sirsmokesalot's Avatar
what size are the front rotors?
I mean, the rears are smaller than the fronts, so....
Old Jul 20, 2006 | 09:04 PM
Default Re: (SirSmokesAlot)
Front = 9.5"
Rear = 9.4"
Old Jul 20, 2006 | 09:05 PM
stock rotors . not sure what size they are. i wanna keep my vx's rims cause took me about a year to polish.......... (2 weeks) damm they look tight.
what part of SA?
Old Jul 20, 2006 | 09:09 PM
kinda by d-town
Old Jul 20, 2006 | 09:11 PM
Default Re: (streetracerjoey210)
Once again, the 13" VX rims will fit.
Old Jul 20, 2006 | 09:16 PM
Default Re: (BlueIntegraBoy)
you have the best info, every time i log on for some quick tech help???,
whole9
Apr 28, 2006 05:58 PM
DC4_MADMAN
Aug 25, 2005 01:12 PM
eg686
21
Apr 4, 2005 05:07 PM
endlesswinterco
Oct 27, 2003 02:59 PM
johnny hatchback
11
Mar 31, 2003 07:11 AM
