Timing belt question for em1...
Old Jul 20, 2006 | 08:20 PM
00siandrew's Avatar
Default Timing belt question for em1...
How often should the timing belt be changed on these motors? Im coming from owning 2 dsm's, so Im a little **** when it comes to timing belts.
Old Jul 20, 2006 | 08:37 PM
Boomer234's Avatar
i think honda recommends every 100K miles
you can also do a visual check on it by removing the valve cover and see how tense it is, if its fraying and so on...
Old Jul 20, 2006 | 09:00 PM
Built Beast's Avatar
Default Re: Timing belt question for em1... (00siandrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siandrew &raquo;</TD></TR><TR><TD CLASS="quote">How often should the timing belt be changed on these motors? Im coming from owning 2 dsm's, so Im a little **** when it comes to timing belts.</TD></TR></TABLE>
All hondas are recommended to change them @ 90k intervals. Be sure to change the water pump at the same time, even if it isn't needed....will help later down the road.
Old Jul 20, 2006 | 10:13 PM
.Kevin.'s Avatar
Default Re: Timing belt question for em1... (Built Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boomer234 &raquo;</TD></TR><TR><TD CLASS="quote">i think honda recommends every 100K miles
you can also do a visual check on it by removing the valve cover and see how tense it is, if its fraying and so on...</TD></TR></TABLE>
I personally wouldn't trust the check method. A belt can look alright one oil change and then the next be screwed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built Beast &raquo;</TD></TR><TR><TD CLASS="quote">
All hondas are recommended to change them @ 90k intervals. Be sure to change the water pump at the same time, even if it isn't needed....will help later down the road.</TD></TR></TABLE>
This is correct 90k. People have gone longer and had no problems, I personally have seen my friends sisters civic go to 150k before it was changed. Just depends on how the car is driven also I belive.
GSE980
54
Jun 19, 2007 11:18 PM
m_cough
May 22, 2007 07:50 PM
Iomega01
Aug 2, 2005 08:12 PM
AnitRiceSuperStar
Jan 31, 2004 12:42 PM
2camsaam
Jul 30, 2003 12:20 PM
