1.6 sohc swap
Old Jul 20, 2006 | 04:39 PM
herath22's Avatar
Default 1.6 sohc swap
I have a civic cx with the 1.5 engine manual tranny and i am swapping to a 1.6 sohc vtec and i was wondering if the tranny from the 1.5 will bolt right on to the 1.6 engine? Also the 1.6 was an automatic and is there any mods i have to perform to allow the clutch and fly wheel to fit on the 1.6? Please help thanks
Old Jul 20, 2006 | 04:56 PM
yellowrexsi's Avatar
Default Re: 1.6 sohc swap (herath22)
direct bolt, just gotta use the clutch and flywheel of the 1.5
Old Jul 20, 2006 | 05:25 PM
herath22's Avatar
The original motor was a none vtec, the new motor will have vtec do i have to create a wire???????
Old Jul 20, 2006 | 05:37 PM
low_hatch's Avatar
hey buddy i believe its a direct bolt job, since most D-Seires parts are interchangeble... but its best to use a vtec gearbox with your motor due to the lower gear ratio's... this is if your looking at a performance point of view..
Old Jul 20, 2006 | 05:40 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herath22 &raquo;</TD></TR><TR><TD CLASS="quote">The original motor was a none vtec, the new motor will have vtec do i have to create a wire??????? </TD></TR></TABLE>
yes you will have to run all the wires necessary for the vtec.
Old Jul 20, 2006 | 06:03 PM
egsleepercivic's Avatar
what year is your car?
Old Jul 20, 2006 | 07:40 PM
instrument's Avatar
i hope you have an arm rest, cause when your car hits vteckhk, OMG!!!!!!!!!!!
wantaDelSol
Aug 20, 2004 12:41 AM
NMHondaEX
Mar 3, 2004 02:29 PM
