Can Someone supply some part numbers for me?
Old Jul 20, 2006 | 04:16 PM
WRTEG's Avatar
Default Can Someone supply some part numbers for me?
can someone please give me the part numbers. This is for a 94 Integra LS, with a manual transmission located in the differential
Page 15-14 of the manual
Side axle oil seal (front passenger side)
Thrust Shim 2.5mm
Bearing outer race
Tapered roller bearing
bearing outer race
thrust shim
shim 79.6mm
here's a reference BUT for a ITR
Modified by WRTEG at 10:07 PM 7/20/2006
Old Jul 20, 2006 | 04:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Can Someone supply some part numbers for me? (WRTEG)
http://www.acuraparts247.com
They have what you need. I believe you transmission has ball bearings for the differential, not tapered roller bearings. The ball bearings are easier to install. You will not know which shim you need until you install the differential into the transmission housing.
Old Jul 20, 2006 | 04:40 PM
Dforce's Avatar
That's what she said!
Default Re: Can Someone supply some part numbers for me? (Dogginator)
or hit up TRE_
Old Jul 20, 2006 | 04:52 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Can Someone supply some part numbers for me? (Dforce)
http://www.barancoacuraparts.c...dIrno=
this may be some part #'s you need, if not look at this site, its cheap OEM parts
http://www.barancoacuraparts.com
Old Jul 20, 2006 | 05:07 PM
WRTEG's Avatar
thanks ya that was from a ITR...didn't have the LS schematic
Boosted Chemist
Transmission & Drivetrain
Nov 6, 2008 07:23 PM
gutted
Aug 26, 2008 01:13 PM
ABK
Jan 22, 2007 08:46 AM
95lstegman
Apr 7, 2005 07:34 PM
pentaq
Feb 15, 2005 09:59 PM
