Problems with acceleration
Old Jul 20, 2006 | 02:44 PM
jdm_eg6_hatch's Avatar
Default Problems with acceleration
Everytime i get on the gas my car shakes cant really notice it till about 55-60 then it just get worse the harder u press on the gas the harder it shakes and when i let off the gas or it stops. umm anyone have any ideas what it could be ??? thought it would be tires or alignment or cv's but then if i let off the gas it would still shake right??? NEED SOME HELP ASAP CANT TAKE THIS MUCH LONGER.... thank you everybody
Old Jul 20, 2006 | 02:58 PM
Max Kling's Avatar
Check your tire pressure.
Look at the rotors see how much is wore off, also feel for any warpage, rotors are decently cheap at autozone and you can throw some on and see if it helps with the shaking. But with rotors thats usally with brakeing.
Also what kind of rims do you have, do you have aftermarket that require the adhesive weights to balance the tires? Check and see if one could have fallen off.
And of course lugnuts.
Old Jul 20, 2006 | 05:20 PM
Default Re: Problems with acceleration (jdm_eg6_hatch)
no aftermarket rims sits on stocks and thanks ill chech that out
Old Jul 20, 2006 | 08:47 PM
Yeah rotors are cool and dont have any trouble while breaking
Old Jul 21, 2006 | 04:41 PM
ANY IDEAS???????????????????
Old Jul 21, 2006 | 06:20 PM
ci_v_ic's Avatar
i had a similar problem when accelerating and cornering on a mitsu i used to own and it turned out to be a wheel bearing. may want to check that?
Old Jul 21, 2006 | 06:52 PM
Default Re: Problems with acceleration (ci_v_ic)
Old Jul 22, 2006 | 02:04 AM
help me please.....
Old Jul 29, 2006 | 04:29 PM
Old Aug 3, 2006 | 11:01 PM
818SpoonITR's Avatar
When was the last time you did a tune up? I have the same prob and i changed my spark plugs and spark plug wires. That might help!
SingleCamin
13
Jan 5, 2010 10:55 PM
ace10414
14
Oct 20, 2008 08:13 AM
azian21485
15
Jun 14, 2004 06:06 AM
genxguy
12
Dec 22, 2003 07:48 AM
nek0
Sep 11, 2002 10:58 AM
