brake fluid question
Old Jul 20, 2006 | 02:26 PM
RE- v8killa121's Avatar
Default brake fluid question
is it possible for brake fluid to be sucked into the motor and cause smoke?
I'm pretty sure this happened to me but i have no clue how it could.
Old Jul 20, 2006 | 02:30 PM
Tyson's Avatar
Default Re: brake fluid question (RE- v8killa121)
your MC is leaking and dripping into the brake booster, which is a vacuum chamber that is directly linked to the intake manifold.
replace your MC, and check your booster and clean out the check valve at the least.
Old Jul 20, 2006 | 02:39 PM
Max Kling's Avatar
Or make sure you even have a check valve on the booster line.
Old Jul 20, 2006 | 02:40 PM
Default Re: brake fluid question (Tyson)
Thanks
i already replaced the whole **** (booster & MC) and i changed that valve with an old one i had laying around. It was a bitch to get it in!
my brakes work MUCH better now. I never knew that brake fluid could be sucked into the motor and cause so much damn smoke.
Old Jul 20, 2006 | 02:52 PM
Tyson's Avatar
yeah, well thats what happened.
fortunately i havent had to mess with replacing the booster. ive always heard its a pain to get under the firewall. i can only imagine given the few times ive had to reach under there for other reasons.
Andyxramirez
Mar 11, 2013 05:56 PM
Chef Andre
Suspension & Brakes
Jul 22, 2010 08:22 PM
UltimX
21
Feb 8, 2006 08:29 PM
Hybrid Invasion
Nov 3, 2003 10:22 PM
