blue smoke
i need an opinion on this, my friend was driving behind me the other day (behind obviously!) and he said when i was pushing hard and especially when i let off the throttle blue smoke comes out the tail, i'm thinking rings, my question is that on the track the car pulls slow past 100 and cant go any harder than 125-130 flat out out, could the shitty rings cause this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 »</TD></TR><TR><TD CLASS="quote">gas should be blue, so rings would not be the problem in that situation</TD></TR></TABLE>
wrong too much fuel is black blue is oil sounds like since most of the smoke is on decel its possible that it could be pcv and or valve stem seals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig »</TD></TR><TR><TD CLASS="quote">
wrong too much fuel is black blue is oil sounds like since most of the smoke is on decel its possible that it could be pcv and or valve stem seals. </TD></TR></TABLE>
X2 do a compression test too.. Also do you have a 5spd or auto.. auto's dont go much faster than 120 if the wind is right...
thanks guys, its a manual, and its wheezing by 120 and is practically crying at 125. i goin to get a comp test sometime soon, i'm hoping its valve stems because i cant afford to crack my bottom end open at the moment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude »</TD></TR><TR><TD CLASS="quote">thanks guys, its a manual, and its wheezing by 120 and is practically crying at 125. i goin to get a comp test sometime soon, i'm hoping its valve stems because i cant afford to crack my bottom end open at the moment. </TD></TR></TABLE>
Im curious to know why you would beat on a motor that is telling you it's not liking it???? not bashing just stating something......
i didnt know there was blue smoke coming out on the overrun, thing smells of gas aswell so i was thinking it was running rich. if i knew there was a problem before yesterday it would not have been on the track.
