Idle Low - Electrical Load Causes 700rpm Difference. What Causes?
Old Jul 20, 2006 | 12:07 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Idle Low - Electrical Load Causes 700rpm Difference. What Causes?
The car when warm will idle at about 900-1000rpm, but when I need to turn on the headlights (sidemarkers also tap into headlights circuit) the idle will drop to 400 and the engine wants to die
I also have a power wire coming straight off the battery to a switch and then to multiple assecories in the car (4 gauges, wideband, shiftlight)
When this is turned on it will also lower the idle a good 150 or so rpm
The headlights are Ebay projectors but I never had this problem last year. Why would the car idle so dam low and why would the load make such a difference?
I did just put in a new battery
Old Jul 20, 2006 | 03:22 PM
yellowrexsi's Avatar
Default Re: Idle Low - Electrical Load Causes 700rpm Difference. What Causes? (PINKS)
could be the alternator is going.
have it checked at a local parts store, its free
Old Jul 20, 2006 | 03:41 PM
PINKS's Avatar
Default Re: Idle Low - Electrical Load Causes 700rpm Difference. What Causes? (yellowrexsi)
Alt is fairly new from a junkyard, pushes 14.5V all day
I lied though, the rpm drops almost 400 with the accesory switch on
Old Jul 20, 2006 | 03:50 PM
was the alt tested by the junk yard or by a parts store
Old Jul 21, 2006 | 05:06 PM
PINKS's Avatar
Old Jul 21, 2006 | 05:13 PM
x2gold's Avatar
agree, sounds like alt prob..
Old Jul 21, 2006 | 08:20 PM
PINKS's Avatar
Default Re: Idle Low - Electrical Load Causes 700rpm Difference. What Causes? (x2gold)
why would an alternator cause a 500rpm drop in idle?
Anyone heard of an electrical load detector?
where is it?
Old Jul 22, 2006 | 05:53 AM
x2gold's Avatar
either diode is going or a wire is grounding out causing the alt to take a bigger load with the lights on. The alt cant produce enough volts for the car to run, then the headlights on. So, the sensors can't function properly and hence the low idle.
Old Jul 22, 2006 | 07:10 AM
EFvtec Yo!'s Avatar
When i swapped the motor in my EK the lights would flicker and it would show that the alernator was not charging and the CEL was on. I found out the CEL was for the Electrical Load Detector which is also controlled by a fuse under my dash. Replaced the fuse and all my problems went away.
Old Jul 22, 2006 | 08:25 AM
PINKS's Avatar
Default Re: (EFvtec Yo!)
ELD - I thikn throws a code 17 right?
Ive gotten that one before
Whats the fuse for?
No way to disable it? I know this alternator is good
Old Jul 22, 2006 | 01:13 PM
PINKS's Avatar
Old Jul 22, 2006 | 02:48 PM
Honda33442's Avatar
Default Re: (PINKS)
code 17 means VSS (valve speed sensor) located in your tranny
Old Jul 22, 2006 | 02:51 PM
Honda33442's Avatar
change your battery and check all the grounds on your engine especially the one on your alt.
Old Jul 22, 2006 | 02:52 PM
Honda33442's Avatar
Default Re: (pinks)
or code 71 means 1st cyl. miss fire
Old Jul 23, 2006 | 06:06 AM
PINKS's Avatar
Default Re: (Honda33442)
for low idle
Old Jul 23, 2006 | 10:26 AM
PINKS's Avatar
bump bump
Old Jul 23, 2006 | 02:07 PM
PINKS's Avatar
Old Jul 23, 2006 | 06:07 PM
PINKS's Avatar
Old Jul 24, 2006 | 02:45 AM
PINKS's Avatar
bumpity bumper
Old Jul 25, 2006 | 03:47 PM
PINKS's Avatar
JAYSCRX420
Oct 12, 2022 11:24 PM
ludedude808
Nov 5, 2006 10:44 PM
PINKS
18
Jul 25, 2006 03:48 PM
96RS
Mar 18, 2003 11:46 AM
cr00klyn718
Nov 12, 2002 04:02 PM
