idling
Old Jul 20, 2006 | 09:44 AM
sensor's Avatar
Default idling
I recently replace my 1995 Honda Civic with a japanese import used 1995 civic engine. Now the engine light comes on after a minute. It idles very rough when you start the engine at that point there is no engine light. after a minute the idling settles down and the engine light comes on. Any one know the reason behind this and what can be done.
Thaks
Modified by sensor at 2:41 PM 7/20/2006
Old Jul 20, 2006 | 03:26 PM
yellowrexsi's Avatar
Default Re: idling (sensor)
gotta find out why the check engine light is on. problems are definetly related
there is a jumper on the pass side, under the glove box. jump that and count the flashes (check engine light). long is 10, short is 1
tell us what it is and we can help
Old Jul 20, 2006 | 08:52 PM
Del Sol Russell's Avatar
I'm having a very similar problem in a 93 del sol 1.5 swapped japan 40k miles I'll let you know what my code thing says if you count your engine check flashes. Also do you ever have problems starting?
Old Jul 22, 2006 | 04:46 PM
sensor's Avatar
Default Re: idling (yellowrexsi)
Engine starts fine. Engine code is 14. I was told it could be air in the coolant. So I bled the radiator. What else could it be.
pindented
Jul 11, 2013 11:07 AM
adez1313
Feb 23, 2013 04:57 PM
cennouu
Jan 12, 2011 07:49 PM
roller
Jun 13, 2004 11:57 PM
eg686
Apr 18, 2003 01:01 PM
