Can it be a bad 3 bar map sensor or hondata?
I run 10 lbs daily on the street and it was just tuned at 16 lbs a few weeks on this map sensor with no problems. I went to the track and couldn't boost over 10 lbs. I turn up the boost and lined up to race and I couldn't go pass 5000 rpm in the 1st gear and the check engine light come on and felt like I hit a wall. So I let go of gas and the engine light went away. It seems like when I hit boost it won't go. Is it the map sensor or the hondata s200?
