help why is my da losing coolant
Old Jul 20, 2006 | 08:05 AM
DB1_559's Avatar
Default help why is my da losing coolant
ok so i was driving yesterday and then i notice my temp gauge was getting hotter than normal.so i make it home to find out my coolant is low again any ideas.but i dont think its my headgasket cause its not smokeing.
ps if it turn out to be my headgasket can i swap in a ls(b18b) head for the extra 5-10 hp,and do anyone know a good coolant flush that will remove rust cause my raditor is nasty rusted
Old Jul 20, 2006 | 08:52 AM
Tizight's Avatar
My car is burning coolant also. I just fill it up every morning. It is only burning about a cup or half a cup a day. so yeah. Check the head gasket it could be a bunch of things. Do you have to crank it a while for it to start?
Old Jul 20, 2006 | 11:34 AM
EK79's Avatar
Default Re: (Tizight)
i do but what does tha mean?
i found i had a small leak and since the engine was hot buy the time i looked it evaporated just make sure all hoses are tight.
Old Jul 21, 2006 | 08:14 AM
DB1_559's Avatar
Default Re: help why is my da losing coolant (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">My car is burning coolant also. I just fill it up every morning. It is only burning about a cup or half a cup a day. so yeah. Check the head gasket it could be a bunch of things. Do you have to crank it a while for it to start?</TD></TR></TABLE>
same thing but it start rite up everytime
Old Jul 21, 2006 | 08:25 AM
AwOrKiNpRoGrEsS23's Avatar
if it's a small leak in your radiator system then you can buy aluminum oxide dust/ ground up aluminum, at any auto parts store for cheap, and pour that into your radiator and run it for a bit and that usually is an easy fix. i did it in my truck and it sealed up the leak i had and never leaked again. so it's a cheap fix, other wise you should find the leak and braze it shut. or have someone do that for you...
Old Jul 21, 2006 | 08:44 AM
trick_db's Avatar
Default Re: (AwOrKiNpRoGrEsS23)
try replace your headgasket.
Old Jul 21, 2006 | 08:56 AM
Jose-aka-Pedro's Avatar
Default Re: (trick_db)
^^ Is that what you say in every thread?
Ok, go thru the basics first, start the car over concrete or blacktop,
Look for leaks, It could be something simple, or it could be pretty bad.
Just depends, could be pletny of things,
As our cars get old hoses begin to crack,
also could be the seal on your water pump, that happened on my old integra, WP went bad and it dripped from there and down the crank shaft pully
Old Jul 21, 2006 | 08:59 AM
trick_db's Avatar
Default Re: (Jose-aka-Pedro)
no, it happen to me before. and i change my headgasket and no more leak. but is up to you.
Old Jul 21, 2006 | 09:01 AM
I understand that,
But its commen sence to check the basics first,
I have done a head gasket and I didnt like it,
8 hours and $500 ( i replaced alot of things, might as well while its apart)
Old Jul 21, 2006 | 09:03 AM
trick_db's Avatar
you brought it to the shop right?
me and my bro work on it since he's a mechanic so basicly just buy parts and labor free.
Old Jul 21, 2006 | 09:24 AM
DB1_559's Avatar
but do anyone know a good raditor flush cause mines rusty but imma changed the thermostat and maybe some hose
Old Jul 21, 2006 | 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">but do anyone know a good raditor flush cause mines rusty but imma changed the thermostat and maybe some hose</TD></TR></TABLE>
most mechanics or auto shops will do that for a price....i know even like oil can henry's and jiffy lube do radiator flushes...
Old Jul 21, 2006 | 12:05 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AwOrKiNpRoGrEsS23 &raquo;</TD></TR><TR><TD CLASS="quote">
most mechanics or auto shops will do that for a price....i know even like oil can henry's and jiffy lube do radiator flushes...</TD></TR></TABLE>
but is there a product that will kill/flush the rust out
Old Jul 21, 2006 | 12:41 PM
93_teg_CT's Avatar
Just take out your thermostat, disconnect the upper rad hose and put a hose in the rad, turn the hose on for awhile and bam, all flushed out.
Old Jul 21, 2006 | 01:51 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">Just take out your thermostat, disconnect the upper rad hose and put a hose in the rad, turn the hose on for awhile and bam, all flushed out.</TD></TR></TABLE>
but the rust how to get it out
Old Jul 21, 2006 | 03:43 PM
BrooX's Avatar
I had this problem once before and it sounds like you have a leak somewhere in your cooling system. from the symptons you describe it was quite similar to mine. I replaced my heater core and that fixed the problem. Check for leaks in your system.
Old Jul 21, 2006 | 08:39 PM
BigD3154's Avatar
Default Re: help why is my da losing coolant (BrooX)
I am slowly losing coolant also. My heater started to get cold at idle and would warm up when the revs came up. Could i be the heater core? Have you checked your oil or radiator for any mixed coolant/oil?
Old Jul 21, 2006 | 10:30 PM
1991 DA's Avatar
Default Re: help why is my da losing coolant (AwOrKiNpRoGrEsS23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AwOrKiNpRoGrEsS23 &raquo;</TD></TR><TR><TD CLASS="quote">most mechanics or auto shops will do that for a price....i know even like oil can henry's and jiffy lube do radiator flushes...</TD></TR></TABLE>
yea and they also half-*** it and charge you 3x the price if you did it yourself.
if you want something done right, do it yourself
Old Jul 22, 2006 | 01:13 AM
numbnuts22715's Avatar
look for leaks in your radiator and radiator hoses, then move to your water pump and see if thats leaking. `
Old Jul 22, 2006 | 09:26 AM
kpop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i was driving yesterday and then i notice my temp gauge was getting hotter than normal.so i make it home to find out my coolant is low again any ideas.but i dont think its my headgasket cause its not smokeing.
ps if it turn out to be my headgasket can i swap in a ls(b18b) head for the extra 5-10 hp,and do anyone know a good coolant flush that will remove rust cause my raditor is nasty rusted </TD></TR></TABLE>
i'm thinking its a small leak
start the car and see if theres any
Old Jul 22, 2006 | 01:28 PM
stpdfasthonda925's Avatar
you know what i did before just uncap the top of the radiator then shove a hose in the top with pressure and turn the hose on u might find it leaking some where or try taki9ng of your valve cover and see if it milky
Old Jul 24, 2006 | 08:56 AM
DB1_559's Avatar
think i got it there is a cut on my tanks things lines
Sivik
Sep 1, 2016 11:59 PM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
A-dub5513
May 18, 2009 04:08 AM
LaOstha
Sep 16, 2006 04:41 PM
kevin96GSR
Feb 3, 2004 06:41 PM
