wiring factory fog lights bought from ebay
Old Jul 20, 2006 | 08:02 AM
honda95civic's Avatar
Default wiring factory fog lights bought from ebay
bought the stock fogs for my 95 ex .. how do they get wired to a switch or the factory switch?
theres two power leads from the fogs.. and a ground.. as well as a relay. should i power the fogs.. and wire them to a switch so when the switch is turned on its grounded causing the fogs to turn on??
any help appreciated. should i tap off battery or can i get the power from my head lights and just have them turn on when my head lights are on.. cuz i wouuldnt mind that
Old Jul 20, 2006 | 09:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: wiring factory fog lights bought from ebay (honda95civic)
Do you have the factory fog light switch?
So I understand, you say there are two power leads from the fogs and one ground do you mean that there is one power wire from each fog light and the fog light grounds have been joined together?
Is it a stock relay or an aftermarket one, [standard SPDT automotive relay]? 94
Old Jul 20, 2006 | 10:04 AM
Default Re: wiring factory fog lights bought from ebay (fcm)
came wit the relay
one ground joined together
one power wire from each fog which i can join together
i have the factory switch which it also came with one but it was black and my interior is grey.. but the stock plug which i dont had wired to the facotry fogs is still there
Old Jul 20, 2006 | 12:22 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
This must of been a used kit? Most new kits come with a wiriing diagram. Is it the stock fog lights.
Old Jul 20, 2006 | 05:06 PM
Default Re: wiring factory fog lights bought from ebay (wrx-killer-Sti eater)
no as a matter of fact it is brand new
Old Jul 20, 2006 | 08:16 PM
White95SiHB's Avatar
What brand is the foglight set? Esuse? Depo? Or is it the real OEM Honda set?
If you can, take the wiring harness and lay it all out on the floor. Take a picture, post it, and chances are that I will be able to tell you which end goes where.
Or if your set is by Depo, check out this link:
http://www.jdmlyfestyle.com/oe...g.htm
Honda CR-V & Element
Apr 29, 2015 10:42 AM
Pussy_magnet_00
Oct 29, 2007 03:46 PM
3.point.2
Jul 20, 2006 06:12 AM
str8edgexx
14
Aug 29, 2002 07:30 PM
acuraLSSE95
Feb 28, 2002 06:39 PM
