changing headers?
Old Jul 20, 2006 | 07:26 AM
ek9tl's Avatar
Default changing headers?
Hey guys i wanna kno if there is any specific way to change headers on a type r? Is there a specific bolt pattern i must follow?
thanx
Old Jul 20, 2006 | 07:38 AM
Syndacate's Avatar
Default Re: changing headers? (ek9tl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys i wanna kno if there is any specific way to change headers on a type r? Is there a specific bolt pattern i must follow?
thanx</TD></TR></TABLE>
Not that I know of but I do it the same way I u'd tighten a headgasket or valve cover down, start in the middle, and do ajacent opposite sides and work ur way out...like
Like this header (I'm pretty sure it's the type R header) I'd do something like
---9-----5------------1 2-------------6------8
---7-------------3--------------4-------------10
Torque 'em like, "okay" tight, nto too tight, but not so u can remove them with ur fingers, then do the same pattern and tighten 'em more...that should put a pretty even seal on the gasket...
Old Jul 20, 2006 | 09:04 AM
Ragecloak's Avatar
Default Re: changing headers? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Not that I know of but I do it the same way I u'd tighten a headgasket or valve cover down, start in the middle, and do ajacent opposite sides and work ur way out...like
Torque 'em like, "okay" tight, nto too tight, but not so u can remove them with ur fingers, then do the same pattern and tighten 'em more...that should put a pretty even seal on the gasket... </TD></TR></TABLE>
qft
Old Jul 20, 2006 | 09:39 AM
eghondafamily's Avatar
when i changed my header i just started at a courner and went in a diagonal line until teh last one.
Old Jul 20, 2006 | 10:26 AM
jadugartir's Avatar
Default Re: changing headers? (eghondafamily)
the haynes manual will give you the torque sequence and torque specs. I suggest buying one unless you want an exhaust leak and a loss of power.
wizeguy1
19
Dec 26, 2006 06:04 AM
sireg6
14
Nov 14, 2006 06:46 AM
Nathavat
Jul 22, 2006 12:36 PM
mr abstract
Acura TSX
Jan 19, 2006 09:28 PM
jeremy.
71
Nov 23, 2003 01:35 AM
