Can I run 15x7 +40 Offset on my EK4
Old Jul 20, 2006 | 01:17 AM
EKRon's Avatar
Default Can I run 15x7 +40 Offset on my EK4
Hi, I am new here. I have some queries to ask about changing rims.
Currently I am using 15x6.5 +45 4x100PCD Honda rims . Planning to change to a set of Rota Slipstream with profile 15x7 +40 4x100PCD.
1) If I change to this rim, can I still use my existing tire with profile 195/55/R15 on the new rims?
2) If I change to this rim, will it rub my fender when doing turning?
Thanks in advance everyone
Old Jul 20, 2006 | 06:10 AM
gabebauman's Avatar
Default Re: Can I run 15x7 +40 Offset on my EK4 (EKRon)
Yes...those rims will fit fine. I suggest you use a 205/50/15 tire though.
Old Jul 20, 2006 | 06:16 AM
EKRon's Avatar
Default Re: Can I run 15x7 +40 Offset on my EK4 (gabebauman)
Hi gabebauman,
Thanks alot for replying. Makes me feel more at ease because I an about to order the rims from Rota.
As for the tires, will they fit into the 15x7 rims because the tires are fairly new. I just changed them in Feb. So, I was hoping that I can used up this set of tires and then get a set of 205/50/15 tire for the next change.
Ur car is very nicely done up.
Modified by EKRon at 11:47 PM 7/20/2006
Old Jul 20, 2006 | 09:17 AM
nsxtasy's Avatar
H-T Order of Merit
Most 195/55-15 tires are approved for rims that are 5.5-7.0 inches wide, so yes, you can use them. They might appear a bit "stretched" on the rim.
Old Jul 20, 2006 | 09:43 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKRon &raquo;</TD></TR><TR><TD CLASS="quote">As for the tires, will they fit into the 15x7 rims because the tires are fairly new. I just changed them in Feb.</TD></TR></TABLE>
Ah...I see...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">They might appear a bit "stretched" on the rim.</TD></TR></TABLE>
Old Jul 20, 2006 | 11:09 AM
ecahatch's Avatar
Senor Miembro
answer to your question is yes, it will work.
i ran 195/50/15, 195/55/15 and 205/50/15 on 15x7 wheels. never had a problem...
195/55/15 was the best to me...seeing that i don't "slam" my car all the way to the ground like most people do.
Old Jul 20, 2006 | 04:23 PM
EKRon's Avatar
Default Re: Can I run 15x7 +40 Offset on my EK4 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Most 195/55-15 tires are approved for rims that are 5.5-7.0 inches wide, so yes, you can use them. They might appear a bit "stretched" on the rim.
IC...Thanks alot nsxtasy
Old Jul 20, 2006 | 04:30 PM
EKRon's Avatar
Default Re: Can I run 15x7 +40 Offset on my EK4 (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">answer to your question is yes, it will work.
Thanks alot too, ECAhatch. Hmm, my car is pretty low. Anyway, I will just test it out and see how the tires is going to take it.
Thanks to everyone who reply in this thread once again.
Old Jul 20, 2006 | 05:59 PM
ecahatch's Avatar
Senor Miembro
do you have pics of how low it is?
the offset on all my 15x7" wheels were 35, meaning they stuck out more...so there is a higher risk of rubbing.
since you will be running 45 offset, should be no worries
Old Jul 20, 2006 | 06:26 PM
EKRon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">do you have pics of how low it is?
Hi ECAhatch,
I will be running 15x7" +40 offset actually.
I have attached a pic of my car:
Old Jul 21, 2006 | 04:51 AM
ecahatch's Avatar
Senor Miembro
nice nice...that looks like a decent drop, not too low. so i think you should be fine...
i can post some pics up for u, of my 15x7's on 195/50/15 and 195/55/15...
just let me know
Old Jul 21, 2006 | 08:37 AM
EKRon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">nice nice...that looks like a decent drop, not too low. so i think you should be fine...
just let me know </TD></TR></TABLE>
Hi ECAhatch, pls do so...Look forward to see ur pics soon.
StinkyTurbo
Wheels
Jul 31, 2010 08:31 PM
DFW
Dec 16, 2006 09:54 AM
DsBananas94LS
Sep 29, 2005 01:43 PM
JM Performance
Sep 23, 2001 02:31 PM
