Transmission weight?
Old Jul 19, 2006 | 10:14 PM
crxisok's Avatar
Default Transmission weight?
anyone know the weight of a D-series transmission. I plan on picking one up, but wasn't sure if i'd be able to carry it myself...anyone know? thanks in advance.
Old Jul 19, 2006 | 10:23 PM
VRD^don's Avatar
Default Re: Transmission weight? (crxisok)
u should be able to pick it up....i've pick up several d series trans myself..its quite heavy..but if your big, built u shouldnt have a problem carrying it..i say it weighs some where close to 70-90lbs...maybe 1XXlbs..never really weighted one..but its quite heavy..o yeah..DONT USE YOUR BACK to carry it..back pain sucks *****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 19, 2006 | 10:24 PM
crxisok's Avatar
Default Re: Transmission weight? (k_motor)
ok thanks. I'm 5'3 skinny small. but i can probably carry 100 lbs if i try hard. Thanks!
Old Jul 19, 2006 | 10:26 PM
VRD^don's Avatar
im 5'7 135lbs and still able to carry that deseries trans.!!!
Old Jul 19, 2006 | 10:27 PM
nappyroots827's Avatar
i carried an accord a20 auto tranny by myself and im sure that weighs more than a d series manual, im sure u can do it
Old Jul 19, 2006 | 10:47 PM
sbarmann's Avatar
I'm 5' 10" and weigh 169 lbs. and can curl my CRX manual tranny with one arm!!! I also enjoy arm wrestling and long walks on the beach.
Old Jul 19, 2006 | 11:04 PM
Contender25
Guest
Posts: n/a
If im in a good mood and feelin strongz then i can pick it up with my mech gloves on with one hand in the starter hole while not bumpin it into my leg, lol.
Contender25
Guest
Posts: n/a
Btw idk how much it weighs, i would say 7-80 pounds?.
Old Jul 20, 2006 | 12:09 AM
2point2's Avatar
Default Re: (Contender25)
I'm short, wimpy, and lazy and I can carry a d-series tranny. a skateboard works good for a b or h tranny
Old Jul 20, 2006 | 12:36 AM
Tyson's Avatar
60 lbs. 70 lbs shipped.
not the easiest thing to lift, but its not hard or impossible. unless you got some disabled back, you dont need to worry.
Old Jul 20, 2006 | 04:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">Btw idk how much it weighs, i would say 7-80 pounds?. </TD></TR></TABLE>
thats quite the weight range haha
Old Jul 20, 2006 | 06:51 AM
Tippyman's Avatar
It's like 64 lbs.
Old Jul 20, 2006 | 06:54 AM
dr_latino999's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">It's like 64 lbs.</TD></TR></TABLE>ish, depending on fluids inside etc
Old Jul 20, 2006 | 11:44 AM
Contender25
Guest
Posts: n/a
You should try holding both the complete hub/spindle assembly knuckles in both hands.
Old Jul 20, 2006 | 11:50 AM
ludesrv's Avatar
I'm 6 foot tall and I weight about 140lbs and I move D series tranny around like it's a tire and I can do the same with b series tranny. Without the fluid they weigh about 10 lbs less. Make sure it's empty. I think the D series tranny must weigh about 60-70lbs empty. B series is about 90-100lbs. It's easy to pick up, carry them and hold them for a long distance is a PITA.
Old Jul 20, 2006 | 02:25 PM
white90crxhf's Avatar
d-series transmission is 70lbs.
not too hard to carry.
Old Jul 20, 2006 | 02:46 PM
Contender25
Guest
Posts: n/a
No not really but you should try lifting a B16 block by itself, i think those weigh maybe 140-150 pounds?.
Old Jul 20, 2006 | 02:49 PM
Loserkidwac's Avatar
D and B manula trannies are light Auto trans is a different story, now carrying a short block by yourself is a little different but 2 people can lift a short or long block no problem
HoopR
Jun 27, 2021 08:03 AM
Clevor
Nov 7, 2013 01:19 PM
integraturbo96
Transmission & Drivetrain
Jun 8, 2009 10:28 AM
Felliph3
17
Feb 26, 2007 08:11 PM
Eg6_JDM
Mar 21, 2002 05:20 PM
