coupe/hatch headlights the same as sedan?
Old Jul 19, 2006 | 08:12 PM
simplegreenmachine's Avatar
Default coupe/hatch headlights the same as sedan?
will the hatch/coupe headlights fit the sedan? and will the coupe bumper fit the sedan without much modification?
Old Jul 19, 2006 | 08:13 PM
BlueIntegraBoy's Avatar
Default Re: coupe/hatch headlights the same as sedan? (TulowSi)
Headlights = yes, bumper = yes with modification
Old Jul 19, 2006 | 08:14 PM
JDM_d15b_eg8's Avatar
yes for the bumper and yes on the headlights cause i've busted a couple headlights and replaced them twice with coupe lights.
Old Jul 19, 2006 | 08:24 PM
Default Re: coupe/hatch headlights the same as sedan? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Headlights = yes, bumper = yes with modification</TD></TR></TABLE>
what kind of modification are we talkin here?
Old Jul 19, 2006 | 08:28 PM
Vtec4me's Avatar
Cut the bumper in half (dead center) and roll out
Old Jul 19, 2006 | 08:49 PM
sirsmokesalot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TulowSi &raquo;</TD></TR><TR><TD CLASS="quote">what kind of modification are we talkin here? </TD></TR></TABLE>
the fenders are different for both bodystyles, so if you put the coupe bumper on, the sides won't mount 100%
Old Jul 25, 2006 | 03:10 PM
Default Re: coupe/hatch headlights the same as sedan? (SirSmokesAlot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirSmokesAlot &raquo;</TD></TR><TR><TD CLASS="quote">the fenders are different for both bodystyles, so if you put the coupe bumper on, the sides won't mount 100%</TD></TR></TABLE>
exactly, you'll have to play with it and basically get it as close as possible, no biggie though
Old Jul 25, 2006 | 04:53 PM
TheLastSpartan's Avatar
Default Re: coupe/hatch headlights the same as sedan? (JDM_d15b_eg8)
are you sure the headlights from a coupe/hatch and sedan are interchangeable with each other?? I had tried sedan corners on the hatch... the corners were a bit longer and wouldn't fit; figured the headlights were going to be the same way so I didn't even mess with it.
Old Jul 25, 2006 | 05:12 PM
Default Re: coupe/hatch headlights the same as sedan? (TheLastSpartan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheLastSpartan &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the headlights from a coupe/hatch and sedan are interchangeable with each other?? I had tried sedan corners on the hatch... the corners were a bit longer and wouldn't fit; figured the headlights were going to be the same way so I didn't even mess with it.</TD></TR></TABLE>
Headlights are the same, but the corners are not.
Old Jul 25, 2006 | 05:13 PM
93civicsedan's Avatar
yes the coupe/hatch headlights are the same. the corners however are different. the coupe bumper will fit the sedan but the sides wont line up. one way to make it line up perfect is to cut the front half of the coupe fender and weld it onto the back half of the sedan fender.
jdm_vtec
Apr 30, 2007 03:47 PM
kit50si
Nov 14, 2006 04:07 PM
xhatchracerx
Honda Civic (2006 - 2015)
Oct 31, 2006 09:55 AM
TBAGGIN
Feb 15, 2005 10:46 AM
Jerminator
Dec 25, 2004 01:13 AM
