Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
MLS gasket for d16a6
Old Jul 19, 2006 | 07:12 PM
twgracer's Avatar
Default MLS gasket for d16a6
I'm tired of blowing head gaskets. Who makes a good race quality MLS steel head gasket for the D16a6?
Old Jul 19, 2006 | 07:40 PM
jsi's Avatar
jsi
Default Re: MLS gasket for d16a6 (twgracer)
http://www.cometic.com/ should do the job, but if you're blowing HGs on an H4 motor, you may have other issues to fix first?
Old Jul 19, 2006 | 10:34 PM
mos's Avatar
mos
Default Re: MLS gasket for d16a6 (jsi)
Would a y8 gasket be illegal? I think that one is a 3 layer metal gasket.
Old Jul 20, 2006 | 12:49 AM
FlyZlow's Avatar
Default Re: MLS gasket for d16a6 (mos)
Gaskets are open, so any head gasket that fits should be legal. The Y8 gasket may be a good option if it's a direct fit. The one I used on my CRX came from http://www.goldeneaglemfg.com. It only got used for 4-5 weekends, but I never had a problem with it.
- Scott
Old Jul 20, 2006 | 06:33 AM
george34's Avatar
Default Re: MLS gasket for d16a6 (FlyZlow)
I don't believe the Y8 headgasket is a direct fit. With the Y8 gasket it will bump your compression up some. I'm pretty sure the Y8 is a 3 layer gasket. I got my 3layers MLS headgasket for $30 from Icon PM composimo if you are interested.
Old Jul 20, 2006 | 07:56 AM
redzcstandardhatch's Avatar
something different
y8 and z6 both slap right on.
both are MLS.
i run a z6 w/ no mods in my stock a6 block/head.
Old Jul 20, 2006 | 10:05 AM
FlyZlow's Avatar
Default Re: (redzcstandardhatch)
The compressed thickness is important in Tom's case because his head is already milled to the compression limit for the class. If his head gasket's compressed thickness is less than the stock A6 gasket, he'll be over the legal limit for the class. I'll see if I can find the info on the stock gaskets online somewhere.
- Scott
Old Jul 20, 2006 | 10:22 AM
Mr Hammond's Avatar
a/k/a Jomo
Are you using the stock composite head gasket (12251-PM5-S02) or are you using the updated metal gasket (12251-P01-004) per TSB 97-047 which applies to 88-95 Civic All, except VTEC?
Old Jul 20, 2006 | 08:22 PM
twgracer's Avatar
Default Re: MLS gasket for d16a6 (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">Are you using the stock composite head gasket (12251-PM5-S02) or are you using the updated metal gasket (12251-P01-004) per TSB 97-047 which applies to 88-95 Civic All, except VTEC?</TD></TR></TABLE>
Thank you, that is the one I was looking for. I have been using the composite, I want the metal one. Thanks Hammond.
Old Jul 20, 2006 | 08:34 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twgracer &raquo;</TD></TR><TR><TD CLASS="quote">I'm tired of blowing head gaskets. Who makes a good race quality MLS steel head gasket for the D16a6?</TD></TR></TABLE>
I'm running a stock after market replacement head gasket on my D16A6 and compression reads 250-265psi without any problems. Something may be up with your head or block surfaces.
Old Jul 20, 2006 | 09:02 PM
twgracer's Avatar
Default Re: MLS gasket for d16a6 (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
I'm running a stock after market replacement head gasket on my D16A6 and compression reads 250-265psi without any problems. Something may be up with your head or block surfaces.</TD></TR></TABLE>
I had a timing issue that was causing some detonation with the head being milled, but I have solved that problem now. I just want the metal gasket when I reassemble.
Old Jul 22, 2006 | 08:55 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twgracer &raquo;</TD></TR><TR><TD CLASS="quote">Thank you, that is the one I was looking for. I have been using the composite, I want the metal one. Thanks Hammond.</TD></TR></TABLE>
Not a problem.
ej1 rep
Dec 22, 2011 09:21 AM
SPD DMN
17
May 2, 2005 08:30 AM
Wes90civic
Jan 19, 2004 11:13 PM
lonefuzzy79
Dec 7, 2002 08:33 PM
