HELP: Rear Brake Swap
ok... I got my setup off an ex/si. Changed the booster, and went on to do the Master Cylinder. Got the put on and BAM!! problems....the brake line won't fit in the master cylinder. The one in red, is the one im having problems with. The brake line connector is too small, same size as the green. My question is, Does anyone know what size of adapter I need so i can go from the big size(5/16th?) to the small size(1/4th?) I also need the thread size and such. And do I even need the bigger m/c?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirSmokesAlot »</TD></TR><TR><TD CLASS="quote">negative, you cannot mix and match with the MC.
hate to say it, but you gotta buy another part</TD></TR></TABLE>
wrong...he can cut the line...replace the fitting with the correct larger one and reflare the line
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuz_ican »</TD></TR><TR><TD CLASS="quote">wrong...he can cut the line...replace the fitting with the correct larger one and reflare the line</TD></TR></TABLE>
you think all that work is worth it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirSmokesAlot »</TD></TR><TR><TD CLASS="quote">you think all that work is worth it?
yes its worth it...i have done this swap plenty of times and it makes a big difference in stopping power....you are upgrading from a 13\16 to a 1"...its a BIG difference...and its not alot of work...itll take an hour at the most to cut reflare install and bleed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">can you just change both lines coming off the prop val, that goto the mc. with steelbradded lines... </TD></TR></TABLE>
you can also just change the lines to steel braided too
also as far as a porpotional valve you can use one from a non-abs integra...like a 94 rs...
</TD></TR></TABLE>yes its worth it...i have done this swap plenty of times and it makes a big difference in stopping power....you are upgrading from a 13\16 to a 1"...its a BIG difference...and its not alot of work...itll take an hour at the most to cut reflare install and bleed...
and exactly why cant i use a abs porportional valve....is there like an extra line off of it?
and would steel braided work?
what lines could i use so that the brake fluid wont eat through them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stingray96 »</TD></TR><TR><TD CLASS="quote">and exactly why cant i use a abs porportional valve....is there like an extra line off of it?
what lines could i use so that the brake fluid wont eat through them</TD></TR></TABLE>
i believe abs proportional valve has an extra line....and you can use steel braided lines...the fluid wont eat through them...
It's an easy 5-minute job to replace a fitting when you have the right tools. It's hardly "all that work." Maybe if you're incompetent or something . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuz_ican »</TD></TR><TR><TD CLASS="quote">it makes a big difference in stopping power....you are upgrading from a 13\16 to a 1"...its a BIG difference</TD></TR></TABLE>
It makes no difference at all in stopping power. A master cylinder upsize only firms up the pedal feel and reduces pedal travel. The car will still stop the same.
Rear disc swaps do little to nothing to improve stopping power as well. They're just easier to maintain, have more friction material options, and less susceptible to fade.
He also didn't mention whether he was doing a front brake swap along with the rear swap. If he's not using the 10.3" front brakes, I wouldn't even bother swapping on a master cylinder larger than 7/8". Honda agrees ('92-95 EH3). All it will do is create pedal modulation and wheel lockup difficulties.
No, you can't. There is a reason manufacturers do not use flexible lines for the entire brake system. Not to mention, I wouldn't want anything but conventional flared hard lines with threaded fittings coming directly off the master cylinder - it's better to lose just one brake when the crimped fitting on a flexible line fails, rather than the entire system.
</TD></TR></TABLE>It's an easy 5-minute job to replace a fitting when you have the right tools. It's hardly "all that work." Maybe if you're incompetent or something . . .
alscrx
May 10, 2008 01:39 AM
