blown headgasket? bogging? GSR w/jrsc
Old Jul 19, 2006 | 05:26 PM
vietxdragon's Avatar
Default blown headgasket? bogging? GSR w/jrsc
1)----ok so im blowing white smoke out of my muffler wehn i hit vtec. I did a compression test and it was 170-190-190-190. i know its supposed to be consistent so would that confirm i have a blown headgasket? i also filled up my coolant to see if it goes down, i wont find out forsure til a week or so. My coolant is green its not milky or anything, oil i s fine as well.
2) my car seems to be bogging/jerks like around 2-3k rpm when im driving normally around town. I have a supercharger on my car. everything is stock besides the JRSC 6psi kit. FMU---. I use this car as DD and it gets annoying. Right wen i hit like 2-3k rpm the car starts bogging a bit then it jerks and goes. Its like my car isnt getting enough fuel> should i try fuel injector cleaner? new fuel filter?(car starts fine) Sea foam?
Old Jul 20, 2006 | 09:42 AM
Default Re: blown headgasket? bogging? GSR w/jrsc (vietxdragon)
TTT what kind of headgasket are people running for a supercharged gsR?
Old Jul 20, 2006 | 09:43 AM
trick_db's Avatar
fuel pump? fuel filter? i doubt is the hg.
Old Jul 20, 2006 | 09:54 AM
Default Re: blown headgasket? bogging? GSR w/jrsc (trick_db)
well i did the compression test it came out 170-190-190-190 so i think i have a blown headgasket. And i dont know if im running lean, i would think i am because of the setup is nearly stock, Does anybody know if my injectors are maxed out? i know i need a tune as well. Im pretty much on a budget
Old Jul 20, 2006 | 09:57 AM
Lauj87's Avatar
check your oil to see if there is any water in it. and check your coolent to see if there is anyoil in it. when you take off the oil cap look under the cap if you see white foam on it then yes your HG is gone.
Old Jul 20, 2006 | 09:59 AM
Lauj87's Avatar
also check your timming sounds like it might be off.
Old Jul 20, 2006 | 12:36 PM
for the timing, i think u might be right , but ill explain it more in depth, during like wen the motor is still kinda cold it'll like bog and jerk at like 2-3k rpm and then once it hits that rpm it just goes. it does that even in 5th gear wen im cruising along
Old Jul 20, 2006 | 01:14 PM
Lauj87's Avatar
when your crusin in 5th and you step on it dose it bog before it pics up? usually when this happens it's because of a retarted timing.
Old Jul 21, 2006 | 08:59 PM
Default Re: (Lauj87)
thats exactly what happens! i looked in the manual for the JRSC its supposed to be like 10* BTDC for 93 octane and 7* BTDC for 92 octane
Old Jul 23, 2006 | 08:31 AM
ok so ive also noticed that my temp gauge is cold most of the time, is this from the blown headgasket?
Old Jul 23, 2006 | 09:12 AM
CompanyFlow's Avatar
Default Re: (vietxdragon)
If you had a blown head gasket, it would overheat. It sounds like timing is off. The soultion to your problem is: Get it tuned.
racekar
Jul 9, 2005 01:32 PM
siis2fast
Apr 26, 2003 10:20 PM
4DRB18C1
Dec 10, 2001 08:46 AM
Rory Breaker
Aug 25, 2001 10:17 AM
