MOTOR JERKING?? HELP! WHATS WRONG??
Old Jul 19, 2006 | 04:02 PM
ph0shizzle's Avatar
Default MOTOR JERKING?? HELP! WHATS WRONG??
alright well i drive a 97 ek with an jdm d15b vtec swap. when i turn my car in the mornin to drive it, it sometimes feels like its really weak and slow like its strugglin and sometimes it jerks. it does this like for 2 seconds then it goes bac to normal and feels fast again.it happens like once or twice each mornin. i have a CEl that only goes on sometimes after like 30 mins of drivin which is 1 and 10(o2 sensor and intake sensor) if that matters.it always had that CEL code on but it just started this jerking/weak feeling recently. what could be wrong?? please help..
also when i turn on my car, my idle is good i think. but my motor vibrates my whole car.. is that bad motor mounts?
Old Jul 19, 2006 | 05:51 PM
Decapsk8's Avatar
Default Re: MOTOR JERKING?? HELP! WHATS WRONG?? (ph0shizzle)
my car was doing somthing similar, jeaking and weakness until i hit 3krpm. i took a look at my distributor coil and it was gray on some parts. it still worked, but not very well. after i changed it the weak/jerky went away. i would at least take a look at it too see if its white or gray anywhere on the plastic
Old Jul 19, 2006 | 06:41 PM
Si_chRis's Avatar
Default Re: MOTOR JERKING?? HELP! WHATS WRONG?? (Decapsk8)
same for me, my rotor was corroded, changed and know its fine
Old Jul 19, 2006 | 10:01 PM
ph0shizzle's Avatar
Default Re: MOTOR JERKING?? HELP! WHATS WRONG?? (JSpeK_EM1)
so.. it could be distributar wire or rotor or anythin? damn
Old Jul 19, 2006 | 10:56 PM
ph0shizzle's Avatar
someone pleasee helppp im hella scared to drive this car around. already blew my old motor . sorry i dont know much bout fixin motors
Old Jul 20, 2006 | 09:39 AM
ph0shizzle's Avatar
bump someone?
Old Jul 20, 2006 | 09:44 AM
DjTripp's Avatar
shifting gears and what not is fine? no difficulty grabbing gears or anything?
Old Jul 20, 2006 | 10:16 AM
ph0shizzle's Avatar
Default Re: MOTOR JERKING?? HELP! WHATS WRONG?? (DjTripp)
shifting gears are finee. its like im drivin at 20mph and i keep on gassin it but its stuck at 20mph like its strugglin and feelin hella weak for like couple seconds (while sometimes it jerks as well) then the feelin goes away and it feels fast again.
Old Jul 20, 2006 | 10:28 AM
deckster333's Avatar
change you distributor cap and rotor
Old Jul 20, 2006 | 02:39 PM
Decapsk8's Avatar
im tellin you man, remove the dis. coil and look at it, see if its gray on any parts. its only like 59$ for a new coil
Old Jul 20, 2006 | 02:53 PM
Max Kling's Avatar
What ECU are you using?
Are you using a P08 or P28 or an OBD 2 ECU?
I use a P28 on my JDM D15B and it boggs on the low end. Feels like it has nothing till about 3, but thats bc my A/F is jacked up. I have a chip burner and know how to use Crome Im just lazy...
Also since its throwing a CEL for your O2 its prolly running rich which makes it bogg and inconjunction with the IAT can cause bogging and fuel holes like the jerking.
Fix the CEL's first.
Edit also I missed the last part about your motor mounts, yes a broken mount can cause jerking.
Old Jul 20, 2006 | 03:36 PM
ph0shizzle's Avatar
Default Re: (Max Kling)
alright well, i only got like 100$ to spend. should i buy a new o2 sensor? or should i get a tune up with distribuatr cap, rotor, sparkplugs etc.
Old Jul 20, 2006 | 03:52 PM
Tad's Avatar
Tad
well first of all, examine whats up with those codes
thats a huge clue,
have you checked your o2 and iat? and related wiring?
o2 will sometimes throw a code if theres something wrong with the cat as well..
though i'm not sure that's you're problem.
also you can take ur cap off the dizzy and examine the rotor inside..
Old Jul 20, 2006 | 04:52 PM
ph0shizzle's Avatar
Default Re: (Tad)
alright, well my car doesnt have a cat, at least i dont think so? there isnt one under the car, everyone says i dont have a cat that checcd out my car, but its strange cuhz i baught my car completelyyy stockd ugly lookin. and i already baught a new AIT sensor cuhz my old one was fried but its stil throwin that code. my friends checkd all the wirings and there all wired up good. i always had the o2 sensor and ait CEL, but it jus recently started this problem. and im running an obd1 p28
Old Jul 20, 2006 | 05:20 PM
ph0shizzle's Avatar
Default Re: (ph0shizzle)
heres a picture of my distributar when i took the plastic cap off. i dont knwo what the orange stuff is but i could wipe it off.
Old Jul 20, 2006 | 06:48 PM
Tad's Avatar
Tad
wut kinda o2 are you running?
cuz jdm d15b's come with a 1wire, and the p28 needs a 4wire o2
the orange stuff is not a good sign,
but it doesn't mean the dizzy is bad ..
Old Jul 20, 2006 | 06:56 PM
ph0shizzle's Avatar
Default Re: (Tad)
oh.. well this motor came from my homies car . i remember my other friend checkd out my o2 and it had 4 wires. he had the p28 in his car and the same d15bswap. and his car had no CEL on. what do you think i should do? i was goin check the distributor coil but i dont really know how to mess with a distributar so i dont want to risk it. do you think it has to be somethin that has to do with my dizzy? and what does the orange sign mean?
Old Jul 21, 2006 | 08:17 AM
ph0shizzle's Avatar
up
Old Jul 21, 2006 | 09:22 AM
JDM-Rota's Avatar
bump
kaluwa3
Dec 7, 2008 01:33 PM
aser1z
Sep 1, 2005 09:12 AM
DC2IntegraTypeR
Mar 1, 2005 06:41 AM
al4t1gbundy
Aug 30, 2004 10:40 PM
JdmIntegra98
Jan 4, 2004 07:05 PM
