Best setup for street-only integra
Old Apr 21, 2002 | 08:40 PM
eric712's Avatar
Default Best setup for street-only integra
Take into consideration adjustability, handling and comfort only. (No AutoCrossing, just street riding)
[Modified by eric712, 5:44 AM 4/22/2002]
Old Apr 21, 2002 | 08:55 PM
kitkatR's Avatar
Default Re: Best setup for street-only integra (eric712)
if it is just for the street why not just get some coilovers and save yourself some money
Old Apr 21, 2002 | 09:01 PM
joeygill's Avatar
Default Re: Best setup for street-only integra (kitkatR)
wouldn't you still need stiffer shocks to go with the lowering on the coilovers?
Old Apr 21, 2002 | 09:08 PM
IGGY's Avatar
Default Re: Best setup for street-only integra (joeygill)
It's just for street, why would he want something stiffer?
Old Apr 21, 2002 | 09:53 PM
threatcon13's Avatar
New User
Default Re: Best setup for street-only integra (IGGY)
skunk2 all day every day.
Old Apr 21, 2002 | 11:59 PM
SIK IN DA HED's Avatar
New User
Default Re: Best setup for street-only integra (ALLMOTORDC2)
weaponR and kyb agx
Old Apr 22, 2002 | 12:01 AM
iH8RICERZ's Avatar
Weapon R and tokico illuminas.... a lil rough ride, but could hang through any turn as fast as you want depending on the tires
Old Apr 22, 2002 | 05:11 AM
intekragsr's Avatar
The term "coilover" means that the shock and spring are incorporated together. This is better since the designers can match the spring rate to the shock much better, than mix matching springs with shocks. The coilovers shock/strut is threaded so they are also adjustable. correct me if im wrong
Old Apr 22, 2002 | 08:50 AM
ITC Racer's Avatar
Default Re: Best setup for street-only integra (intekragsr)
You are getting close- coilover simply means the coil spring is installed around the shock/strut unit. When most people refer to coilovers, they actually mean adjustable or height adjustable coilovers. This is done either by a threaded sleeve installed over the shock/strut or by cutting threads into the shock/strut body.
For the street, I plan on picking up some Tokico Illumina shocks and some Eibach (~1" lowering springs) when the time comes. The Eibach springs should be slightly stiffer than stock which is needed to prevent bottoming since you are losing suspension travel by lowering. Koni yellows are my second choice for shocks based on their reputation for durability under road racing applications.
The big thing when comparing springs to shock/struts is the spring rate. A good dealer will know how these work together for the application and can advise accordingly.
Hope this helps.
Old Apr 22, 2002 | 08:51 AM
Tweakmeister's Avatar
Tean HA, go all the way or go home
Old Apr 22, 2002 | 02:32 PM
LillDragun's Avatar
Default Re: Best setup for street-only integra (ITC Racer)
i was thinkin bout getting the comptech springs and riding on the stock suspention for a lill while. maybe get some koni yellows when i get nuff skrills
Old Apr 22, 2002 | 03:39 PM
BranzLS's Avatar
Well if you are only street riding, and wanna save some cash then YES just get some coilovers. Ground Controls are around $300, Skunk 2's about $275 and hell you can get a decent set for a flat $200 if you look! After that you can get some struts and shocks but thats gonna take ya over a grand easily. Get some coilovers, and invest in struts and sways for handling on the street and your ride will be pretty good.
Old Apr 22, 2002 | 04:30 PM
Razor's Avatar
Default Re: Best setup for street-only integra (BranzLS)
neuspeed/h&r sports with koni yellows
Old Apr 22, 2002 | 10:43 PM
MrFatBooty's Avatar
Screw the damn coilovers. It's a street car. Who needs to adjust their ride height on a regular basis? Shocks affect handling MUCH more than springs. That's where I'd spend the most money.
I'd snag some KYB AGX, Tokico Illuminas or Koni Yellows and match em with a set of lowering springs. Eibach, H&R, Neuspeed, Comptech, whoever. The springs really aren't that big of a deal. Adjustable damping can do way more to affect the handling of the car.
If you don't want to adjust anything ever, get some Bilstein HD shocks and take yer pick with the springs.
Old Apr 23, 2002 | 12:40 AM
GokuSSJ4's Avatar
Default Re: Best setup for street-only integra (LillDragun)
Teins and there not that expensive!
Old Apr 23, 2002 | 12:50 AM
ingrate's Avatar
25 Year Member
Default Re: Best setup for street-only integra (Spoon1)
ground control is good.. but if you don't want to adjust the height then H&R sports are a pretty good choice.. i've gone through 3 sets of springs in 1 year.. i think H&Rs are the best springs for street.
BTW what's up with the "Smoke Weed Everyday" thing in every poll?
Old Apr 23, 2002 | 06:09 AM
brwnrice's Avatar
Default Re: Best setup for street-only integra (In7egrity)
h&r sports/tokico illuminas. i love em!
Old Apr 23, 2002 | 08:05 AM
JohnnyK's Avatar
Zeal B6 and coat it with WD-40 every two weeks to one month
Old Apr 23, 2002 | 08:33 AM
GSRwBOOST's Avatar
can you say "to hell in a hand basket" cause that's where this thread went...
Rob.
Suspension & Brakes
Jul 12, 2006 04:40 PM
civicsareslow
Suspension & Brakes
20
May 17, 2006 07:35 PM
Nader_D
Jun 25, 2003 11:14 PM
tegasaurus
Jun 24, 2003 08:43 PM
Typerc716
Jul 31, 2001 04:53 AM
