problem...with my dc5
ok well i dont know if it could be a burnt clutch or wat..but when travling in maybe 3thrd gear then i step on it just a little.. the rpm gose crazy..like maybe from 3 to 6 .then it might even stall on 6 until my speed gets higher..then rpm starts moving agin.. can anybody help me out cause i dont know wats going on..thanks.
Most likely its your speed sensor, this happened on my old beater 97 ford taurus. Pretty easy to change on that car, but not sure about a dc5?
Definitely get it checked out though and good luck
Take it to a dealer to check out. For clutch slipage get on the road abotu 20mph, toss it in 4th gear and gas it. If the rpms go up but you are getting no power to the wheels, then the clutch is gone.
If its just ... skipping rpm ranges then there is another issue. Is there a CEL or anything like that?
