Need help wiring ecu pin D21 on p28
I'm looking at my harness by my ecu which is a p28. The pin D21 is cut and does not connect to anything..... where is it suppose to connect to? Help anyone
thanks
thanks
that diagram totally helps explain things to me... but um... where is this map sensor wire suppose to wire to??? I checked all wires by the ECU and non of them are cut... they're all connected and thats why im not sure where it goes...??? If anyone can direct me to where it goes... so i can wire it straight up to it... that'll be nice
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu3g »</TD></TR><TR><TD CLASS="quote">what do you mean C1?
any one else have a clue to where d21 wire up to??? if so lmk
thanks mucho</TD></TR></TABLE>
B18C1
B18C1
to the map sensor
to the map sensor
hey crxified thanks for the map post... that acutally helped me out..... but i wasn't sure what you were trying to ask in your map post.... as for me when i did my brothers b18c1 swap..... we didn't use the map sensor from the ex/si engine harness.... instead we used his map sensor that was coming from the fire wall......... as for the map sensor from the ex/si engine harness we just left that unplug.... anyways what i would like to do was .... de-pin from the ecu, the map sensor from the fire wall... and re-pin the map sensor from the exi/si engine harness from the shock towers to the ecu... to make it look oem... anyways.... thanks for the help
thats what i did. i pined it from the map on the firewall to teh passenger shock tower plug to make it look semi stock, it looks better than having wires run through the firewall to the ecu directly. if u want a pic, i could get u 1 sometime of where i wired mine to.
aser1z
Sep 7, 2005 09:23 AM
dingusjt
Feb 11, 2003 07:16 AM
