How much hp do you get from a .............
Old Apr 21, 2002 | 07:55 PM
vteckiller's Avatar
Default How much hp do you get from a .............
How much power do you get from a high flow cay? Is it worth putting one on? which would be the best for a 2001 itr.
Old Apr 21, 2002 | 07:56 PM
Type Goch's Avatar
New User
Default Re: How much hp do you get from a ............. (itrfreak)
it's worth it.
Old Apr 21, 2002 | 07:57 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: How much hp do you get from a ............. (Type Goch)
What's a cay?
Old Apr 21, 2002 | 07:59 PM
vteckiller's Avatar
Default Re: How much hp do you get from a ............. (itr009)
I mean high flow cat
Dropspeed's Avatar
I assume Cat. With my Mugen header, Mugen exhaust both 2 1/4 I picked up 5 whp and 5 ft pds on the dyno at peak. The best was the 15 pd ft and 12 whp near 4200 rpm as confirmed by the Dyno.
Matth
Old Apr 21, 2002 | 08:03 PM
Rob :190:'s Avatar
Default Re: How much hp do you get from a ............. (Dropspeed)
so a high flow cat is a good upgrade, even if the rest of the exhaust isnt quite as high flow?
matt: i've got the Mugen header(S? ) as well, what cat did you use, and how did you hook it up?
Old Apr 21, 2002 | 08:04 PM
Bob#455's Avatar
These gains are for the header/cat/exhaust combo right? Or did you really get 12 whp and 15 ft/lbs. just by adding a high flow cat?
Old Apr 21, 2002 | 08:09 PM
1GreyTeg's Avatar
He's either dyslexic or just sloppy...
The New car smell is strong in this one...
A.
Old Apr 21, 2002 | 08:40 PM
IGGY's Avatar
Default Re: How much hp do you get from a ............. (Bob#455)
I wonder if cats add THAT much horse power, just like neon lights do. j/k
Old Apr 22, 2002 | 05:28 AM
Dropspeed's Avatar
No that is Just the cat alone, It was the bottleneck in the system, The car already had the intake, exhaust, header, vtec controller , cam gears, underdrive pulley..........The cat alone was good for 5whp and 5pdft at peak. The 12whp and 15 pd ft was in the midrange not peak. One of my good friends ownes a dyno so everytime I make a change the car is strapped on the dyno for comparision.
Mattj
kornerk12
Apr 23, 2006 04:32 PM
mugenracer
Jun 23, 2002 05:36 AM
TeamTooQuick
Apr 27, 2002 01:08 PM
tweekerz
Nov 10, 2001 01:02 PM
ITR #1202
Oct 24, 2001 01:07 AM
