Steering wheel vibration
I've got a 95 JDM H22 ( Avid race mounts, stock swap axles) in a 93 EG Si and when I go past 140 the steerign wheel shakes like crazy like it's going to fall off or something. Didn't have this problem before. What could it be? Bad alignment, driveshafts, wheel bearing? Also when I brake you feel pulsation under the car and on the pedal as if it's coming from the driveshaft.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anth2k4 »</TD></TR><TR><TD CLASS="quote">I've got a 95 JDM H22 ( Avid race mounts, stock swap axles) in a 93 EG Si and when I go past 140 the steerign wheel shakes like crazy like it's going to fall off or something. Didn't have this problem before. What could it be? Bad alignment, driveshafts, wheel bearing? Also when I brake you feel pulsation under the car and on the pedal as if it's coming from the driveshaft.
Thanks</TD></TR></TABLE>
alignemnt, rotors warped..
just don't go 140
just don't go 140
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anth2k4 »</TD></TR><TR><TD CLASS="quote">I've got a 95 JDM H22 ( Avid race mounts, stock swap axles) in a 93 EG Si and when I go past 140 the steering wheel shakes like crazy </TD></TR></TABLE>
Its called terminal velocity...... I hope to hell you are not driving like that on public roads
GOGOGOOGO DRIVE ON PUBLIC ROADS, I'M ALL FOR YA SPEEDING MAN, ALL FOR YA RUNNIN THAT THING OUT LIKE IT'S MEANT TO BE RUN...NOT LIEK SOME JERKS ON H-T WHO BUILD ****** VTEC B20'S WITH TURBOS AND NOS AND CLAIM THEY OBEY THE SPEED LIMIT, GOGO SPEED, TI'S GOOD TO SEE A HONDA ENGINE RUNNING 140, GOGOGOGOGOGOGO
more power to ya..
In any event, definately, definately sounds like ur tires are out of balance..and if u have some extra cash laying around (like 100 bucks) I would get a 4 wheel alignment as well...
more power to ya..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">GOGOGOOGO DRIVE ON PUBLIC ROADS, I'M ALL FOR YA SPEEDING MAN, ALL FOR YA RUNNIN THAT THING OUT LIKE IT'S MEANT TO BE RUN...NOT LIEK SOME JERKS ON H-T WHO BUILD ****** VTEC B20'S WITH TURBOS AND NOS AND CLAIM THEY OBEY THE SPEED LIMIT, GOGO SPEED, TI'S GOOD TO SEE A HONDA ENGINE RUNNING 140, GOGOGOGOGOGOGO
more power to ya..
In any event, definately, definately sounds like ur tires are out of balance..and if u have some extra cash laying around (like 100 bucks) I would get a 4 wheel alignment as well...</TD></TR></TABLE>
fyi: he's in canada 140km/h, not miles you retard
more power to ya..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
My bad didn't catch that. But yah check the balance on the tires, if you have a run out gauge you can check to see if the rotors are warped a little bit (that's all it takes) and yes a bad drive shaft can cause it also. Just start with the less expensive first.
</TD></TR></TABLE>My bad didn't catch that. But yah check the balance on the tires, if you have a run out gauge you can check to see if the rotors are warped a little bit (that's all it takes) and yes a bad drive shaft can cause it also. Just start with the less expensive first.
just don't go 140</TD></TR></TABLE>
This would only occur when he would be braking. Try balancing your tires. And for God's sake, please don't drive in public like that. Save it for the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">This would only occur when he would be braking. Try balancing your tires. And for God's sake, please don't drive in public like that. Save it for the track.</TD></TR></TABLE>
my bad lol
my bad lol
sicky
Suspension & Brakes
12
Oct 22, 2008 07:22 PM
h22sedan01
Aug 14, 2007 02:14 PM
katb16vo
Mar 26, 2004 09:47 AM
