FS/FT: All Motor EJ2
i'm just wanting something differant. i havn't had this car for long. but if you know me you know i can't keep anything for a long time...i get tired of it lol. some of the stuff i just put on not to long ago. i have taken to car up to 8800rpms safely. the car will come with a set of homemade ITB's. i have pics of them on the car but i took them off due to not the proper tuning. they came off a gsx-r 1000. the motor has about 10k miles on it.
i'm really looking to trade for either an Intergra with a jdm front end. (don't care what motor is in it) or another civic/integra with a swap in it. let me know what you have and/or your offer for the car
Engine:
95 B18B1 swap
Gold B18A1 Vavle Cover
Clutch Masters lightweight flywheel (8.5 lbs)
ACT HD/SS clutch kit
Shotpinned stock rods (Hendrins racing)
B18C5 P73 ITR pistons (standard bore)
OEM Honda factory piston rings
Golden Eagle Vac. Manifold
Moroso oil pan
ARP head studs
ARP rod bolts (1.8L 8MM (for LS-VTEC) 208-6001)
P&P Head with 5 ang. valve job
Crower 404 camshafts
Crower Valvesprings
Crower Titanium retainers
Stone head gasket
Mr. Gasket exhaust manifold gasket
Hondata Heat Sheild intake manifold gasket
STR adj. cam gears
ITR throttle cable & bracket
Skunk2 Intake Manifold
Stock LS throttle body
B&M fuel presure regulator
B&M fuel presure gauge
AEM high flow fuel filter
Taylor 10mm plug wires
99 ITR fuel injectors and fuel rail (240cc)
STR cam seal
Tanabe exhaust
Kteller resinator
DC sports 4-1 header USDM
OBX lightweight underdrive crankshaft pulley
Body:
Stock White (i have gallon of CW i'll give with the car)
VIS Carbon Fiber Hood
Hood Pins
JDM Amber Corners
Clear Side Markers
Mugen Front Lip
JDM Foglights with yellow lens
Hood Spacers
Mild Wire Tuck
Battery moved to trunk
Wheels:
Brand New 15" Rota Attacks (Gold)
New Tires...nothing special
Suspension:
Drop Zone Coilovers W/ Bump Stops
Front and Rear upper strut tower bars
Steal Chromoly full race traction bars
Energy suspension solid motor mount inserts
Energy suspension solid Shift bushing kit
Interior
Auto meter 5'' tach with shift light
Auto meter CF A/F meter and pod
OBX Short throw shifter
Type-R Shifter
Tunage:
Mugen spec chip (8800 rpm rev)
JDM S-AFC (Generation 1)
PICS:
The ITB's
Engine:
95 B18B1 swap
Moroso oil pan
ARP head studs
Crower Valvesprings
Stone head gasket
STR adj. cam gears
STR cam seal
Tanabe exhaust
Kteller resinator
Body:
Hood Pins
JDM Amber Corners
Clear Side Markers
Mugen Front Lip
Hood Spacers
Mild Wire Tuck
Wheels:
Suspension:
Interior
Type-R Shifter
Tunage:
PICS:
The ITB's
