b20 motor, stock 99-00 parts, hasport, obd1, apexi
Old Jul 19, 2006 | 01:01 AM
duggy's Avatar
Default b20 motor, stock 99-00 parts, hasport, obd1, apexi
First off, if you don't like my prices, or have something negative to say, please keep it out of this thread. Act like ladies and gentlemen and PM me. No need to ***** this thread up. Lowballers, need not apply to this thread. Thanks. -management
Alright people, I need to clear this stuff out of my garage ASAP.
Motor:
I have a JDM B20B that was purchased off of passwordjdm. It doesn't have VIN number on it because in Japan, they do not use the VIN # system. This motor already has a bunch of stuff done to it, IE: AEM Cam Gears, LS intake manifold, and is all converted to LS stuff ready to be dropped into an EG or EK. It will come with a GSR transmission and if you choose, a stage 5, 6 puck ACT clutch with 9lbs flywheel and ACT pressure plate for another $200. I am asking $1600 for the whole thing, and if you want the clutch, then add another $200 on top. This motor was pulled out of an EG, so if you have an EG, this will drop right in. The GSR transmission was pulled off my JDM GSR motor and has ABSOLUTLY NO GRINDS AT ALL. This thing is MINT! The swap will come with a OBD1 P75 (LS) ECU, motor mounts, shift linkage, but will not come with any axles. I will have to check what motor mounts I have laying around, but I'm sure you can use your stock mounts.
The only thing that will be parted out of this motor is the transmission. I will let this MINT GSR tranny go for $550.
EK/99-00 SI:
99-00 SI A/C compressor - I bought this thinking I could use it on my swap, but I can't. My loss, your gain. - $100
99-00 SI Distributor - Also bought this thinking I could use it, but I can't. -$120
99-00 SI AC bracket - Pulled off a B16A2. I am not sure if you can use this mount on swaps, but it's worth a try. - $40
99-00 SI Rear T bracket - This is the bracket that you need to do swaps on EKs. Very hard to find and here is one that you can use to do a b series swap - $65
99-00 SI ECU - $75
99-00 SI Airbox - $40
Stock CX gauge cluster with no tachometer. Has 112k miles on the clock and is a great replacement if your stock one is broken or whatever - $30
Hasport motor mounts for EK. The stock number on them is EKSTK and according to the website will fit any b series or d series motors. This is only for the transmission mount, and the driver side mount. The driver side mount is missing a bracket that goes along with the mount to bolt up, but can be purchased from hasport for $20 dollars. I do not have the rear mount. - $100
CRV gauge cluster that lights up amber in color. Very nice alternative to the SI gauge cluster that everybody else has. Be different, buy this CRV gauge cluster. - $70
MISC:
K&N 3" air filter. Will fit AEM intakes. Replace your old dirty one with this brand new one. - $45
GSR stock fuel pump. This is great for people with swaps. $40
EG stock tail lights - $40
GSR OBD1 harness. A very very hard to find harness that is in PRISTINE condition with no sensors cut AT ALL! - $150
Stock EG CX and a 99-00 SI harness that has some wires cut on it. Great if you need some pins to take off - $30 each
APEXi N1 Exhaust. A bit dented up at the bottom from being so slammed but is still a great muffler. This is the axle back only and has been cut off. It is a turbo muffler and is still very very functionable. - $50
5zigen axleback pre-angled exhaust for EK- $100
The only things I will trade for are the following:
GSR oilpan must be stamped P72 and cannot have any dents or stripped threads on it.
99-00 EK tail lights in pristine condition.
Anything else that is worth my time.
Contact me on AIM. If I am not there, leave a message.
All items are sold as is.
Modified by duggy at 7:30 PM 7/27/2006
Old Jul 19, 2006 | 09:04 AM
duggy's Avatar
bump
Old Jul 19, 2006 | 12:48 PM
duggy's Avatar
bump!
Old Jul 20, 2006 | 10:24 PM
duggy's Avatar
bump!
Old Jul 21, 2006 | 07:19 AM
duggy's Avatar
bump
Old Jul 21, 2006 | 09:15 AM
urname7698's Avatar
pm'd
Old Jul 22, 2006 | 07:49 AM
duggy's Avatar
bump!!!
Old Jul 27, 2006 | 06:30 PM
duggy's Avatar
bump
lrayford
10
Nov 13, 2008 12:33 PM
murtnabila
Northern California (Sales)
Feb 3, 2006 11:46 PM
litterbox
Jul 29, 2005 08:48 AM
Dorikamu
Jan 7, 2002 06:48 PM
